Neon Supercharger
Old Sep 29, 2004 | 05:23 PM
Neonsxt0486's Avatar
Neonsxt0486
Default Neon Supercharger
Have yall heard anything about a neon supercharger in the works. I know i'd be first in line to have one. I need to know if i should wait for one to come out or go turbo. Thanx
Old Sep 29, 2004 | 06:20 PM
LowSlowNeon's Avatar
LowSlowNeon
Default RE: Neon Supercharger
I don't know of one, but I'm not sure. There is plenty of turbo stuff, check all the different threads on here for more info about them.
Old Sep 29, 2004 | 10:57 PM
tyson724's Avatar
tyson724
I havent heard of any superchargers.. Im going with a chill factory
Old Oct 1, 2004 | 06:50 AM
casper's Avatar
casper
If you are talking about the superchargers on ebay, I hate to break the new to you, but all they are is marine engine compartment blowers for about $25-$50 on West Marine.com, with a $5 switch included. I have not figure out if there is any gain with them, but if so its low-end, because the max CFM I have seen is like 600 CFM and your stock throttle body will pull more than that at high rpm, it might help a little by taking adding some force air, but not much, especially high R's.
Old Oct 2, 2004 | 04:23 AM
Cr@zy Squ33's Avatar
Cr@zy Squ33
Those Marine blowers you are talking about Casper actually restrict the flow of air. Mostly in part by their CFM. It's not enough to produce power.
And yes, I have seen a Supercharger kit for the Neon. But that was many a year ago. The reason why you don't see superchargers on 4cylinders is because a supercharger is belt driven. Which puts a heavy load and draw on the engine and on a 4 cylinder, what the Sueprcharger produces is lost to the engine. Because a 4 cyl would have to work twice as ahrd to produce power from a supercharger, which is why you see turbo's on 4 cylinders.
And in many ways, a turbo is far superior to a supercharger because you aren't wasting energy to produce power with a turbo liek you are with a supercharger. A supercharger on a 4 cylinder is not cost effective.
Old Oct 5, 2004 | 12:04 PM
Altima_wb's Avatar
Altima_wb
Turbos have far more potential in a 4 cyl. application over a supercharger. IMHO screw the supercharger and go turbo.
