Electrical & Cluster Problem, HELP!
Old Jul 17, 2007 | 02:13 PM
03SlvrNeon's Avatar
03SlvrNeon
Default Electrical & Cluster Problem, HELP!
I have an 03 Neon se, its been acting up with electrical problems. In the mornings or if its been sitting ( i would say 6hrs or more) gives me a hard time starting. Car Wont crank over, lights inside go out when i turn the key. Battery is good, autozone tested it, dealer tested it a few months back at the time they reflashed the PCM.They said they couldnt find anything wrong.. When i jump it , car starts right up, Anyways Headlights come on, radio turns on, But when i turn the lights on, the cluster lights and the radio turn off..And just yesterday the needle on the cluster went all the way around so its below 0MPH point. I see the needle jump when i turn the key, but since the little resting bar is in the way it wont go up.. Need help??
Old Jul 17, 2007 | 07:27 PM
RickMN's Avatar
RickMN
Default RE: Electrical & Cluster Problem, HELP!
Classic symtoms of a dirty ground cable. Clean the battery terminals. Clean the batt negative to engine, batt neg to body, engine to firewall. Then see how it works.
Old Jul 21, 2007 | 11:24 PM
03SlvrNeon's Avatar
03SlvrNeon
Cleaned the crap outta the grounds and put some anti corrosion stuff on, havent had problems since last reported, but still have the cluster & radio lights going out when i turn the lights on.. Dimmer switch??Voltage regulator?? And the speedo needle went all the way around and is still below 0mph...
