2005 Neon died for no reason
Old Jul 30, 2007 | 10:35 PM
LilRed's Avatar
LilRed
Default 2005 Neon died for no reason
My 2005 Neon was idling in park as my husband andI were switching cars. He got in his and then with no warning of any kind, the Neon had completely shut off. At first I thought I didn't see him turn it off, but lo and behold, when I tried to crank her up, nothing. Not even a click. She won't even try to turn over. Any suggestions as to the problem and solution would be much appreciated. Thanks!
Old Jul 31, 2007 | 01:21 AM
Flash_Gordon2392's Avatar
Flash_Gordon2392
Default RE: 2005 Neon died for no reason
That sound strange,because my neon 2004 is one year behind yours.Did you take her to your dealer?And she should still be under you power train warrenty!If I was you,I would have her check out because that dont sound right.[sm=sorry.gif]
Old Aug 3, 2007 | 03:19 PM
neoncrazy101's Avatar
neoncrazy101
was the battery light on? could just be a bad alt./dead battery due to bad alternator.
Old Aug 29, 2007 | 04:06 AM
jmja9281's Avatar
jmja9281
you might want to check your connection that runs from your posititive battery terminal to your fuse box under the hood. If that is not the problem check you fuses under the hood by the battery and air box.
Old Sep 11, 2007 | 08:25 PM
bone33's Avatar
bone33
did you put it in park and try to start it?
