bogging problems
Old Apr 28, 2008 | 06:37 AM
alicia.brown@xerox.c's Avatar
Default bogging problems
I need some help! I have a 98 dodge neon DOHC. It has a bogging problem. When i am driving normal there is no problem as soon as i come down on it, it is missing. I have replaced the plugs and the wires. Someone told me that it could be a timing problem and that i should change the CAM sensor but i dont want to spend a bunch of money if that is not the problem. Anyone have any ideas?
thanks
Old Apr 28, 2008 | 11:26 PM
N30N's Avatar
N30N
Default RE: bogging problems
ouch?so what its just missing the gears
Old Apr 29, 2008 | 05:41 AM
no it goes into gear fine it is just when i step on it, acting like it is not getting enough gas. someone said that could be the CAM sensor but i do not want to buy another 100.00 part if it is not going to fix the issue. The coyle was also replaced
Old Apr 29, 2008 | 07:51 AM
it is giving a code 42 which is a misfire but i have changed the plugs the wires the coyle so i dont no where to go from here
Old Apr 29, 2008 | 07:52 AM
i meant code 43
Old Apr 29, 2008 | 02:36 PM
12 volt's Avatar
12 volt
the ignition coil could be the problem, another thing it could be is the o2 sensor. if your bogging down all the time i would say coil, if your bogging down on hard accel could be the O2 sensor.
try taking it to an autozone had having them run a diagnostics test, sometimes the OBD2 scaner will pull better codes
Old Apr 29, 2008 | 02:40 PM
12 volt's Avatar
12 volt
more
"Note- Many possible problems cause this code. go step by step to solve this. Will also depend on your other codes if any. This code can cause cel to flash if misfire is not intermittent. An OBD-II scan tool can tell you which cylinders are missing (or keep reading for a trick)
First determine If misfire is fuel or spark related. Check for spark by removing spark plug and with it touching a grounded surface have assistant crank engine. If there is no spark check plugs, wires, voltage at coil, green wire with orange strip to pcm. Last resort coil-pack and pcm."
Old Apr 30, 2008 | 01:04 PM
thanks everyone for the help. Got it hooked up to a computer and found out that the injector for the fuel is a little clogged
Old May 5, 2008 | 03:03 AM
N30N's Avatar
N30N
OMG now my car is doing that....i changed the plugs and it quit and 3 days later it started BS
Old May 5, 2008 | 06:45 AM
my car didnt ever quit it was just working like crap but now that i have been driving it, it is starting to work normal again.
