speed mods
Old Apr 30, 2008 | 09:29 PM
wHipPrOper3's Avatar
wHipPrOper3
Default speed mods
what can i do to make my car faster without doing nothing major..meaning im stickin with my 2.0 but wat could i do to maximize its performance? i suppose or rather been thinkin a new intake and exhaust system?
Old May 1, 2008 | 09:08 AM
dtjackten's Avatar
dtjackten
2nd gen neon peace keeper
Default RE: speed mods
that word be a good start, and the bestthing u could do is do a port and polish on the head, along with a big came and valves, and valvesprings..... that u would see the best power range out of it..
Old May 1, 2008 | 10:40 AM
sparky3009's Avatar
sparky3009
I would start with a cai, new header, bored out tb, and lightened pulleys.
Old May 2, 2008 | 11:28 AM
wHipPrOper3
wow, if yall don't mind could u break all that down for me please? thnx
Old May 3, 2008 | 05:10 AM
wHipPrOper3
i did a bit of research and found out alot...cool, tha only things i need explainin are the big cam and valves, cai? also, with the lightened pulleys..is that just one or more?
Old May 3, 2008 | 10:50 PM
reppinthe202's Avatar
reppinthe202
homemade 3.0 cai,modernperformance.com's 55mm Tb,2.5catback exhaust,longtube header,mopar or af/x pcm,some slight weight reduction,new IM,............
Old May 4, 2008 | 03:07 PM
Ghost Neon 2's Avatar
Ghost Neon 2
Weight reduction? I see this floating around a lot. Since when was a neon heavy? It is probably just my point of view, but when you get faster, that will make traction an issue, and having weight helps with that. That is why the performance model of a car is heavier than the base. There are other ways to address the issue ( like going with a 2.4L) but you seem like you are looking for cheap power. Most are any way.
1.Look for an Iceman intake, or make a Cold Air Intake or CAI from a 3.0L chrysler car. There are links around.
2. Look on ebay for a Megan under driver pulley for the crank shaft. This will free up some horsepower. There are many different brands. I went with the Af/x since I got a good deal on it, but I hear the TTI udp is the best. By how much who knows, and i doubt it is worth the cost. Could be wrong though.
3. Dump the stock manifold and get a header. What kind? A Long Tube Header or a mid length? What to buy? I went with this:
Stainless steel means it never rusts, plus I had waned it for years. I made a huge difference in my neon, and a 1/3 the cost of most dohc lth's. Mine was $86 shipped and took a week to arrive.
There is more but keep in mind your suspension and brakes are what keeps that power under control. Address them first is my advice.
Old May 4, 2008 | 04:51 PM
berretta96's Avatar
berretta96
ORIGINAL: Ghost Neon 2
you should have used that $85 to pay back some of the people you ripped off
Old May 4, 2008 | 04:56 PM
reppinthe202
ORIGINAL: berretta96
i agree dont ever ever get performance parts from ebay
just go here and they have everything u will need http://www.modernperformance.com/index.php?cPath=160
Old May 6, 2008 | 01:19 PM
berretta96's Avatar
berretta96
you've obviously never ridden in a weight reduxed car. A buddy of mine has a dohc 1g all motor car that dynod 50 more ponies than my all motor car. He also has an r/t tranny and I have a 3:55. He gutted about 300 lbs out of the car and he gets WAY better traction off the line now. This is an even bigger factoron a FWD car that is "dragging" weight rather than pushing it. Not to mention...every bit you can loose increases your power to weight ratio! What difference does it make that a neon is already light.
