Failed burnout attempt.......
Old Jan 14, 2005 | 07:38 PM
TJW815's Avatar
TJW815
Default RE: Failed burnout attempt.......
u can do some adjusting by backing up and hitting your brakes with some repetition... it won't be alot but it should help
Old Jan 14, 2005 | 10:18 PM
casper's Avatar
casper
Yeah I tried that with mine it did help a little, maybe its just the neon, I am used to a car that if I am going in a straight line and I pull the e-brake the tires will both lock up, mine just squeaks and squeals and slowly comes to a stop. And yes the pads and drums are fine.
Old Mar 5, 2005 | 10:21 PM
qpg's Avatar
qpg
My boyfriend keeps telling me this. What does this do and how does this work.
Does anyone know how to adjust the back breaks, so they do grab a little more. I realize front does 80+%, but just had the boyfriend change break pads, front warn considerably, back almost look new. He is just not sure how much to tweek them. Any advise.
Old Mar 5, 2005 | 10:33 PM
RayDog26's Avatar
RayDog26
you got a Durango ?? if so your kinda in the wrong forum you need to go to the Durango forums out on the main page... i don't know any thing about ttem.. they might be auto adjusting they might not be. usually u just turn it until you can't pull the rotor off by hand and that should be tight enough and they adjust the rest of the way... if im not mistaken.
Old Mar 5, 2005 | 11:15 PM
morningpride's Avatar
morningpride
She can post where ever she wants!
Rear brakes can be adjusted with the wheel off. there is a small opening on the back of the backing plate. There is a small adjuster with teeth on it right behind it.
using a screw driver, the idea is to rotate the teeth (at very small intervals) thus adjusting SMALL amounts of pressure onto the drum.
It 's better to have someone who has done it before there to help you, because over adjustment will destroy your brakes and drums.
Old Mar 5, 2005 | 11:24 PM
RayDog26's Avatar
RayDog26
dude calm down..... i never said shje couldn't post here... i only suggested the other forum because they are owners of the same truck as her and they might be able to help her more and give her the answer she needs to solve her problem..... if i offended her im sorry that wasn't my intention.
Old Mar 6, 2005 | 03:04 AM
GroundControl's Avatar
GroundControl
yea my back brakes always worked good. then i changed them and they dont work for shi*. i know how to adjust them but i though they do it automaticly. If i pull the e-brake it will hold the car but if i gas it then the car will pull away unless its wet out lol.
Old Mar 6, 2005 | 02:25 PM
RayDog26's Avatar
RayDog26
i tried adjusting mine for almost a half an hour driving in reverse and pulling the ebrake.... you name it i did it.... i used every trick there is for tightening up the auto adjusting brakes... i self adjusted them some not alot..... but still no success..... my only conclusion is "a neon doesn't have enough power stock to do a burnout" lol
Old Mar 6, 2005 | 02:43 PM
casper's Avatar
casper
I have since tried doing a burnout. Its not that hard to do at all, I can do it without the ebrake at all.
Old Mar 6, 2005 | 02:45 PM
RayDog26's Avatar
RayDog26
well your car prolly have more power then my base model highline sedan(auto)......lol
