2nd gen auto to 1st gen man
Old May 26, 2008 | 02:27 AM
dodgedude88's Avatar
dodgedude88
Default 2nd gen auto to 1st gen man
can they be swapped? ive tried to look up the past threads but to no avail. i have an05 dodge neon auto, and want to know if i can swap a manual out of a 98.
Old May 26, 2008 | 07:49 AM
Ghost Neon 2's Avatar
Ghost Neon 2
Default RE: 2nd gen auto to 1st gen man
It will bolt up, but you will need to make some adjustments. As your neon is an automatic, you will need the clutch pedal assembly, clutch cable ( you will have to drill a hole in your fire wall to use), a 5speed shifter and the cables, the brackets securing the shifter cables to the 5speed mtx, a 2G trans mount, reverse plug sensor pigtail wiring, a clutch, and a 2G 5speed pcm. You will have to inquire on what years your 05 can use. I have some 2G shifter boots if you need one. The center consol for 2G neons is the same for auto and 5 speeds. You will not need the bobble strut on the 1G as the 2G neons do not use them. You could throw one in there for the heck of it
Old May 26, 2008 | 09:09 PM
dodgedude88
im gonna buy a 98 neon auto and that was gonna be the decision point breaker of buying it, if it could swap trannys or not. so i just have to get those 2g parts and it will work?
Old May 27, 2008 | 12:35 AM
Ghost Neon 2
You have a 05 with an atx, and want to swap over a 5sp transmission off a 98 neon. Is this correct?
Old May 27, 2008 | 01:34 PM
03neonRT's Avatar
03neonRT
You'll also need to drill holes in the firewall if you go with a 1st Gen or MY2000 transmission since they use a cable clutch setup.
Old May 27, 2008 | 09:50 PM
Ghost Neon 2
ORIGINAL: Ghost Neon 2
Beat ya to it
Old May 28, 2008 | 02:42 AM
dodgedude88
yeh this is correct a moondo
Old May 29, 2008 | 07:12 AM
Ghost Neon 2
Want a transmission?
Old May 30, 2008 | 03:26 AM
dodgedude88
im buying a whole car for 400 big ones so i can swap everything i can over
Old May 30, 2008 | 09:46 AM
Ghost Neon 2
Check to make the clutch pedal assembly from a 1G will be compatible with 2G neon. I'd recommend a new clutch cable, new clutch, and a new reverse plug sensor.
