What's the rpm at 70 mph for a 2001 Neon?
Old Jul 1, 2008 | 03:16 PM
mat663's Avatar
mat663
Default RE: 70 mph
Dude, i was also wondering why i have this same problem. I have a 2001 SE and at 60 i have 2500 and just like Mike, 70mph also makes 3000 rpm. i was just thinking it was only my car have problems but i guess it's a common thing. I worry that this higher rpm is making our cars less fuel effiecient than if it were to be 500 rpm less.
I WISH I HAD OD TOO!!!
Old Jul 1, 2008 | 04:16 PM
LowSlowNeon's Avatar
LowSlowNeon
Default RE: 70 mph
Mine is around 2800rpms at 70-75mph. I have a 5 speed though, and it pretty much destroys other cars on gas mileage.
Old Jul 1, 2008 | 05:43 PM
Mike89's Avatar
Mike89
Default RE: 70 mph
Mat663. Does your Neon shift twice or 3 times. Mine shifts 3 times.
Old Jul 1, 2008 | 11:31 PM
N30N's Avatar
N30N
Default RE: 70 mph
ok mike if im off the throttle around 70 its around 2500.if im tapping the throttle to stay or gain speed then its around 2800-3000.and you do have OD cause in 3rd mine shoots up to like 4200.
Old Jul 2, 2008 | 12:16 AM
N30N's Avatar
N30N
Default RE: 70 mph
btw my tires are 195/60R15
and im not into tires.lol
and my rims are 15
Old Jul 4, 2008 | 01:55 AM
Mat00ES's Avatar
Mat00ES
Default RE: 70 mph
Holding it steady at 70, its 3000rpms on the dot. As soon as I let off it drops to 2300-2500rpms.
Old Jul 4, 2008 | 02:22 AM
Mike89's Avatar
Mike89
Default RE: 70 mph
Yep, that's what mine is too. What size tires do you have?
Old Jul 5, 2008 | 05:59 PM
Mike89's Avatar
Mike89
Default RE: 70 mph
Here is a good quote I got in another forum that explains a bit more about the 3 and 4 speed deal.
The 4 speed trans will have a circle around the D.The 3 speed trans will simply have a D (no circle).If your car does have the 3 speed ,a 6 cylinder is a 670,and a 4 cylinder is a 470.The Overdrive is the 42TE,also known as the 604.When i said a 3 speed is a 1 to 1 ratio,that is exactly correct for an old RWD car like a RoadRunner,Nova,etc.It is slightly different on a transaxle,even a 3 speed one,as Chrysler takes the 1 to 1 ratio of the rotating assembly,same as the old musclecars,and ramps it up slightly with a big gear and a smaller gear,much like bicycle sprockets.The smaller gear makes the pinion spin ever so sligthly better than the 1 to 1 ratio.You feel two shifts,1st to 2nd gear,then 2nd to 3rd gear,then on the 3 speed trans,you feel the clutch apply in the torque convertor,also known as TCC for Torque Convertor Clutch.This apply feels like a 3rd shift in some cars as the engine Rpm's can drop 200-500 Rpm's.As for the two different yet similar cars,tire diamter can dramatically alter a vehicles cruising Rpm's,better or worse.In addition,transfer gears are available with different tooth counts for varying final drive ratios depending on the weight and horsepower of the car.
Old Jul 6, 2008 | 02:51 AM
N30N's Avatar
N30N
Default RE: 70 mph
ORIGINAL: mat663 mat00ES
wow dude that sucks mats.i thought you guys had it.man stay off the e-way.lol j/k
Old Jul 6, 2008 | 03:51 AM
Mike89's Avatar
Mike89
Default RE: 70 mph
I'm just gonna pretend there is a circle around the D when it shifts that 3rd time as I cruise at 3000 rpm. heh heh
