Tip for people with subs
Old Feb 11, 2005 | 02:29 AM
GroundControl's Avatar
GroundControl
Default Tip for people with subs
I have some subs in my car and the trunk ratteling is very annoying from time to time. I took the plastic off around the plate so it doesnt rattel. also the hook inside the trunk that holds the trunk down can be adjusted. adjust it a few mm down and it will pull the trunk down tighter. This is just a tip if you dont want anything vibrating. It also sounds better inside the car.
Old Feb 11, 2005 | 03:01 AM
95n30n_nyg's Avatar
95n30n_nyg
Default RE: Tip for people with subs
also another tip, if the above doesnt fix the rattles like in my case.. i took a small, very small, maybe square inch piece of dynamat and wrapped it around the "hook" inside the trunk that the trunk lid latch clamps down onto. note this isn't for a professional LOOK but for fixing rattles, it did thw trick for me.
Old Feb 15, 2005 | 12:22 AM
98neonsport's Avatar
98neonsport
groundcontrol, how can you adjust the hook down a few mm?
Old Feb 15, 2005 | 02:19 AM
GroundControl
i dont no if its the same on your 98 but i have a plastic piece covering it. i cliped it off and there is a screw. loosen it and pull the hook down a tiny bit, then tighten the screw back up. I have to shut my trunk harder for it to close but it worked nice. untill i sold my system.
