Car Problems
Old Apr 15, 2005 | 02:29 PM
Etanimulc's Avatar
Etanimulc
Default Car Problems
These are some car issues that I have. I was looking for some help from you all: A. My antenna shakes really hard at idle sometimes; like if I'm sitting at a light. B. The left side of my car is making a rubbing sound mostly when I accelerate, like something is rubbing against my tire. C. My car makes a screeching noise after it rains, when I start it up or when I accelerate for the first time for that day. I have 93.000 miles on my car.
Old Apr 15, 2005 | 02:48 PM
Neonsxt's Avatar
Neonsxt
Default RE: Car Problems
dont know about 2 of them but the screetching sound probably means your belt needs to be replaced
Old Apr 15, 2005 | 03:35 PM
Etanimulc's Avatar
Etanimulc
I drive a 2000 Dodge Neon. What kind of belt are you talking about? Give me the actual name of the belt.
Old Apr 15, 2005 | 04:32 PM
Mnementh's Avatar
Mnementh
Your belts name is Harvey Johnson. (Sorry, couldn't resist)
I'm no expert, but I think he's refering to the drive belt.
Old Apr 18, 2005 | 06:16 AM
RadarLove's Avatar
RadarLove
There are 2 belts that need fairly frequent replacement. Both are on the passenger side of the engine, both dirven by a single pulley that's attached to the crankshaft. The inner one (closest to the engine) is the alternator belt. The outer one is the accessory belt that drives the air conditioning compressor and power steering pump. Quality belts run $15 or less for each. Installation isn't remarkable difficult, but you may want to at least get a Hayne's or Chilton's manual if you aren't familiar with basic mechanics (it's just turning wrenches...). Don't know how much labor would be at a shop, my guess is somewhere in the $40-60 range.
Rubbing sound? Sort of a grinding sound maybe? First, make sure there isn't actually something rubbing against the tire... Extremely worn brakes might be the culprit, although the squealing from the metal feeler tabs would probably clue you in looong before that... My first hunch would be a worn wheel bearing. If you go to a shop for this, you will get raped... Figure $80 for the bearing (their cost), they'll probably try to talk you into a new spindle to go with it for another $150, just to be safe... and then another $250 for labor. Firestone gave me a quote of just over $450. I laughed, went to the junkyard, picked up a whole spindle for $45 (with a 90-day warranty), installed it in an afternoon, and went back to Firestone to finish the alignment... PRobably a step or two above "novice mechanic", but it really wasn't all that hard.
Shaking antenna. Try tightening it? Dunno. My antenna shakes, but my suspension is a bit stiffer than most.
Best of luck!
Old Apr 18, 2005 | 02:30 PM
Etanimulc's Avatar
Etanimulc
I'd like to thank you all for your help.
