Even a eletric shop is clueless "PLEASE HELP"
I have a 200 plymouth neon and I have changed out everything from the cam sensor to the coil pack even tried a different pcm. Well the problem is if you disconnect the camshaft position sensor the car will start but run like major SH*t but once you plug the wire back it it will not get spark. If anyone know please help me fix my car thats in a shop.
the cam sensor is telling the coil pack when to spark? so with the cam sensor plugged in, if its not getting the message to spark to the coil pack then there has to be a wiring issue from the sensor to the pack? follow the wires and see if you can replace a harness from the cam sensor to ???? or from the coil pack to ??? some where. thats my best guess. cam sensor is new right? cause i know some sensors if you touch the wrong part of it, the oil or grease from your hands will get on it and ruin it.
