Problems at the Strip...
Old Jun 18, 2005 | 03:09 AM
Neonsxt's Avatar
Neonsxt
Default Problems at the Strip...
so i went to Silver Dollar Raceway tonight and Raced my car in the 1/4 for the first time,i always thought my car was suppossed to run a low 17 stock, its an 04 SXT ATX, i know the MTX should run a low 16 so i thought th ATX would run a low 17?? well my best time was 18.412 @ 76.07 MPH, that is terrible, i was very dissapointed in the car, do you know any reason the car would run that slow???? here is all the stats from tonight for this particular run....
R/T- .588
60'- 2.879
330- 7.930
1/8- 12.013
MPH- 61.07
1000- 15.465
1/4- 18.412
MPH- 76.07
i was goin up against a fauxbody mustank and got it handed to me big time he ran a 13.2 @ 109.64, please if you can tell me something that may cause my car to lack power like it does i would appreciate it very much...
Old Jun 18, 2005 | 06:16 AM
BDM's Avatar
BDM
Default RE: Problems at the Strip...
Start buying stuff for your engine...
Cold Air Intake, 60mm throttle Body, Underdrive Pully. Those should help you quite a bit.
Old Jun 18, 2005 | 06:30 AM
RadarLove's Avatar
RadarLove
Stock ATX puts 20 HP less to the ground than a stock MTX. All the bolt-on's available aren't going to make you as quick as a tranny swap would. Low 18's sounds right for that heavy of a car. Sorry for the bad news...
Old Jun 18, 2005 | 01:43 PM
Neonsxt's Avatar
Neonsxt
so my cars only puttin 112 HP actually???? well if thats the case then i guess that is about right i just always heard that i was supposed to run a low 17...yea i wish i could have gotten an MTX but they didnt have any at the time and i had to have a car then....but a transmission swap will be so expensive its not funny, i know i want to get into the 16's, besides turbo what would be the best way to accompolish that?? thanks guys, Chris
Old Jun 18, 2005 | 01:47 PM
Neonsxt's Avatar
Neonsxt
oh and actually that wasnt my best time, here are the results from my best time
R/T- .466
60'- 2.819
330- 7.873
1/8- 11.975
MPH- 60.56
1000- 15.443
1/4- 18.403
MPH- 75.82
Old Jun 19, 2005 | 01:17 AM
RadarLove's Avatar
RadarLove
No, your car is only putting 91 HP to the ground, give or take a pony or two. Probably less. Only the 1995 SOHC Neon achieved its advertised HP rating of 132 HP. The camshaft was changed for the 1996 model year and dropped flywheel HP to 128 HP. Recently - definitely for the '04 model year - the compression ratio was dropped from 9.8:1 to 9.3:1 for regular SOHC's, lowering power even more (2-3 HP by most accepted guidelines). Dodge is still allowed to advertise the car as 132 Hp, even though it really isn't.
Drivetrain losses happen. With manual trannies, most people use a 15% guideline. I've found a 10% + 10 HP is more accurate as power goes up. There are no good guidelines for auto trannies, but most factory units run in the 20-25% HP loss range at best. I have seen dynos from a bone stock 1995 Neon SOHC MTX hitting 111 HP. I have seen dynos from a bone stock 1995 Neon SOHC ATX hitting 91 HP. Maybe the 4-speed has less drivetrain losses than the 3-speed, but I wouldn't bet on it.
Your car should weigh about 2800 pounds with driver and whatever you keep in the trunk, glove box, etc. (dry weight is 2635). At sea level, on a nice day, your car should be running low 18's at just under 75 mph using various calculators available on the web. With the same weight, same engine, and a manual tranny, the car might run very low 17's at just over 80 mph.
Old Jun 19, 2005 | 01:39 AM
LowSlowNeon's Avatar
LowSlowNeon
Try low 16s. I ran 16.3 at around 85mph completely bone stock with my neon...that is MTX. I have since got that down to a 16 flat at 87mph with a filter and catback exhaust.
Old Jun 19, 2005 | 02:23 AM
BadStratRT's Avatar
BadStratRT
The Forum Tyrant
i run 16.1s with an ATX...
but i agree that time is about average for your car...the ATX is a real drag....im just now getting near what the MTX RTs run...[:@]
Old Jun 19, 2005 | 02:36 AM
LowSlowNeon
ORIGINAL: BadStratRT
Yeah but with how much more HP then he has...80? If i had the same HP as you in my car I'd be a good second or more faster.
