2005 Neon Sensor Question
When I went to change the oil yesterday on my girlfriend's 2005 Dodge Neon 2.0L I saw the following sensor just hanging down (please see pictures).
Would anyone happen to know what this sensor is for, what it's called, for the air conditioning maybe? The car doesn't show any check engine light so I'm wondering how important it must be.
Also if anyone would have a good tip on how to get the broken end of the sensor out that would be extremely helpful because I can imagine it will be tough to get it out.
Any help would be much appreciated!
A/C Pressure Switch
After more research I figured out that the sensor in question must be a pressure switch for the air conditioner.
In order to replace this sensor do you just simply remove the old switch and replace with a new switch or is there more to it than that? Just wondering if removing this sensor will blow refrigerant out when you remove it or what the story is with replacing this. Any help would be appreciated.
