need help on making my 2.0sohc faster with stock parts.
Old Sep 22, 2011 | 10:55 PM
neon 41's Avatar
neon 41
Default need help on making my 2.0sohc faster with stock parts.
looking for help on making my 2.0 sohc faster with stock parts. i race a neon on a drit track , the rules say i can only use stock parts . does any one have any advice on interchangeable parts ie... 2.0 sohc 2.0dohc 2.4 . if you read between the lines in the rules a stock part is a stock part. so if any combo between the 3 engines will work i can use them. thanks
Old Sep 22, 2011 | 11:55 PM
blazendizz's Avatar
blazendizz
if your motor is running at top notch then theres already stock parts so there is not much you can do..... can you cut the cat off and straight pipe it?
Old Sep 23, 2011 | 06:29 AM
neon 41's Avatar
neon 41
yes i can and have done that already. iv heard that you can take dohc pistons and put them in a sohc motor to bring compresion up. just tryin to get more hp out of my sohc .
Old Sep 23, 2011 | 04:38 PM
chew*'s Avatar
chew*
Well the RT or ACR offered 9-5-1 ratio I beleive and a larger cam stock, best thing you can do to get better power though is to remove airbox and top cover over air filter.
Old Sep 23, 2011 | 09:02 PM
chew*'s Avatar
chew*
Few more things you can try.
Supposedly ATX w/OD had 55mm throttle bodies. I have yet to find one measuring over 52mm.
You can do this. It creates just a tad more torque but mostly HP however it's band is very wide and sloppy as opposed to a true CAI which increases a narrow and precise band based on length.
Bt stock do they mean only mopar wire's, and champion plugs, if not granatelli wires and some NGK iridiums will help smooth out throttle response.
You can also drop to the next range thermostat and plugs to get the engine to run richer via computer if you can get enough air in an out to not bog it down.
As far as the punching out cat suggestions it could cause issues. Removing cat requires you to add a defouler so it doesn't trigger CEL which would make it non stock.
The R/T 2.0 has stock headers, a ported head and intake + cam ( finding one is hard ) or you could port your own head but kinda pointless without a better intake.
Srt4 exhausts run 2.5" stock iirc and a less restrictive muffler.
Last thing which is very helpfull is doing A/C delete, and only running power steering and alternator belts. I have the correct belt part # if you need it for a hassle free job.
It helps the engine rev up quicker.
Old Sep 27, 2011 | 10:37 AM
chew*'s Avatar
chew*
Here's an oldschool tip to gain a couple HP.
It's called indexing.
Basically you mark the open end of your plugs at the top of the spark plug. You want that index to face the intake port on all your plugs. You will need to buy indexing washers specifically made for this. They come in various sizes sort of like a feeler gauge. Most commonly found at real speed shops, not these make the car look faster accesory shops.
moroso part #71910 avg cost $20 at a local speed shop, sure if you shop around you can find them cheaper.
Old Sep 28, 2011 | 04:32 PM
hemi4spd's Avatar
hemi4spd
one word "DIET" throw away anything that will slow u down passenger seat, backseats, trunk Carpeting, Spare tire, jack, Speakers ect.....
Old Oct 27, 2011 | 08:30 AM
Dodgeman1990's Avatar
Dodgeman1990
I remember reading somewhere that on the 95-99 if you pull off the piece of rubber seal on the back of tge hood above theair box it allows cooler air to come down behind the air horn thus allowing the motor to have a cooler air charge. But if you ever blow a coolant line it will let the steam fog up the windshield. Iirc it frees up 2-3 hp over stock. Supposedly no dyno tests proving. But it seems plausible.
Chris
Old Oct 27, 2011 | 06:33 PM
darthroush's Avatar
darthroush
Section Moderator
Chris
So, making a ghetto cowl induction hood? It works fine on carb'd engines (when it is a real cowl hood), but on a FI system where the air enters the engine through a sealed intake system that sits at the front of the engine bay...not so much. They are for looks nowadays.
I'd doubt that there are dyno tests proving this because of what I said above.
