fitting 18 on neon
Old Mar 22, 2004 | 08:24 PM
neonrt01's Avatar
neonrt01
Default fitting 18 on neon
does anyone know if 18 will fit on a neon? if so would i have to change the computer to fix the spedometer? this is the first car i ever owned i had all trucks before, so by putting the 18 onto the car is it going to mess with my ratio like it would in a truck?
Old Mar 22, 2004 | 09:37 PM
Dodgegirl19's Avatar
Dodgegirl19
Lady Administrator
Default RE: fitting 18 on neon
I'm sorry... do you mean 18 inch rims?! LOL! Yes, you'll have problems with speedo, mileage and clearance, turning ratio on sharp turns... everything that's to be expected...
~Amanda
Old Mar 23, 2004 | 12:32 AM
dustyloins's Avatar
dustyloins
Hall of Fame Member
Yes, you'll "mess up" a lot of stuff. Dodge designed the car for all the parts to work in harmony...changing things like that is only inviting trouble down the road, unless you make other mods....[sm=smiley14.gif]
Old Mar 23, 2004 | 04:30 PM
neonrt01's Avatar
neonrt01
so what kind of mods should i do to get it to work right? i knew i would probally have to change the computer around, but i just didn' t know if they would fit like turning and so on. thanks for the help
Old Mar 24, 2004 | 05:13 AM
71RoadRunner's Avatar
71RoadRunner
You do not need to replace the computer, just the speedo gear in the transmission. 18's will fit, but you have to either run an extremely low profile tire(probably 30's) or replace your struts with coil overs. For your tire size as well as wheel size, check out this link to Tire Rack.
Old Mar 25, 2004 | 08:17 PM
neonrt01's Avatar
neonrt01
thanks for all your help i look into that. i really want to get eighteens to fit thanks for all your help
Old Mar 25, 2004 | 08:29 PM
shiltz's Avatar
shiltz
you'll probably have a really hard time even finding 18" that fit on a neon, I used to have a 98 neon and I never saw anything over 17 for them, personaly I wouldn't go over 16" or 17" anyways a 1st gen neon, the sidewalls will be way to small, 1 good pothole and you're out $300-400 from warping a rim, my stepbrother had that happen when he put 18" on his old ford escort. I had put 16" on mine, the one problem I did have was with the extra width of the rims they were rubbing on the suspension in the rear and I needed to put spacers in, 18's will be even wider than the 16's.
Old Mar 26, 2004 | 08:47 PM
neonrt01's Avatar
neonrt01
well right now they come with 16and half, and there is a huge gap from the tire and the body. so i was looking at some 17's but that wouldn't make the gap smaller. so it just comes down to it custoimizing the 18 and i want 18. to fit
Old Mar 27, 2004 | 10:46 AM
71RoadRunner
The only way to eliminate the wheel well gap is to lower the ride height of the suspension.
Old Mar 27, 2004 | 02:49 PM
neonrt01's Avatar
neonrt01
i have been looking at that, they have a lowering kit fully adjustable from 1 to 4 inches. i am planing on getting on this summer, but i was only going to get one if i could get 17 on it. so i figured if i could get 18 on it i wouldn't lower it. but right now i may be getting ready to trade it in for the srt-4. the local dodge dealer in my town just got a lighting blue one in and i feel in love with it. i have test drove twice already.
