will not crank
Old Apr 19, 2013 | 06:10 PM
TylerGandy's Avatar
TylerGandy
Default will not crank
i have an 2003 sxt 5 speed dodge neon and i swaped the motor with an 02 sxt automatic dodge neon and it will not crank?
Old Apr 20, 2013 | 02:39 AM
darthroush's Avatar
darthroush
Section Moderator
There are different sensors and possibly some different wiring for those sensors (can't remember exactly right now; been awhile since I've gone over the specific differences). I'm assuming you didn't change any of those? '00-'02 is different than '03-'05 because of the two different computer systems.
Old Apr 20, 2013 | 03:53 AM
TylerGandy's Avatar
TylerGandy
i took all the wiring and sensors off the 2003 motor and put them in the 2002 motor before i put it in and it still will not crank.
Old Apr 23, 2013 | 08:31 PM
I_Ride_Neon's Avatar
I_Ride_Neon
If it wont crank at all you need to use a test light or multimeter to check for power, ground, and ignition signal to the starter. Works your way up to the fuses, relays, and terminals. Does the fuel pump kick on?
Old Apr 26, 2013 | 02:13 PM
TylerGandy's Avatar
TylerGandy
it will turn over but its not getting any fire to the fuel rail or the spark plugs.
Old Apr 26, 2013 | 06:08 PM
darthroush's Avatar
darthroush
Section Moderator
Work your way through this guide here: How to Troubleshoot a No Start (Chrysler 2.0L, 2.4L)
It gives you a good walkthrough on what to check for crank but no start conditions.
Old Apr 28, 2013 | 12:46 AM
TylerGandy's Avatar
TylerGandy
would it help if i took my 03 computer systems to a dodge place and got it reprogrammed.
Old Apr 28, 2013 | 04:00 AM
darthroush's Avatar
darthroush
Section Moderator
Got it reprogrammed for what?
Old Apr 28, 2013 | 04:38 PM
TylerGandy's Avatar
TylerGandy
somebody told me to take it and get it reprogrammed and it would help.
Old Apr 30, 2013 | 12:26 PM
TylerGandy's Avatar
TylerGandy
if i wire my fuel injectors straight to the computer will it help.
