turbo
Old Nov 2, 2005 | 09:58 AM
dodgeme's Avatar
dodgeme
Default turbo
i am wondering if anyone knows where to get a turbo system cheap enough for the horsepower. is there anywhere that you can get the srt turbo, because alot of times you can get a turbo from the old motors cheaper. if there are any ideas please let me know. thanks a lot.
Old Nov 2, 2005 | 10:27 AM
LowSlowNeon's Avatar
LowSlowNeon
Default RE: turbo
Yeah you can. But you will have to do some work to make it work. Guess it depends on what year neon you have, SOHC or DOHC.
Old Nov 2, 2005 | 02:28 PM
casper's Avatar
casper
Default RE: turbo
Your best bet if you are a novice is going to be to buy a kit. Both Chill factory and Hahns racecraft make them. They range from about $2200 - $3500 if I remember the prices right and come with everything you will need to turbo the motor. I would suggest spending the extra money if you get one and getting the intercooler also.
Old Nov 7, 2005 | 05:10 PM
got boost?'s Avatar
got boost?
Default RE: turbo
Here is a couple of links with listings for Neron turbo kits: http://www.modernperformance.com/dcx/2k_hrc.shtml, this is for the Hahn as mentioned before and heres a link for the Chill Factory: http://www.chillfactory.us/autoturbokit.html. Hope this helps and good luck!
