Prospective first car: '03 neon shakes when in neutral and rattle the steering wheel
Old Oct 30, 2016 | 01:03 PM
kmwise97's Avatar
kmwise97
Default Prospective first car: '03 neon shakes when in neutral and rattle the steering wheel
Looking to buy a 2003 Dodge Neon and the seller is telling me that it needs motor mounts due to the shaking. We started it up and I ran it through all the gears and it shakes to the point that the steering wheel rattles.
That's the my first issue, the second being the oil light was on and my Step-Dad tells me that it usually means that there is no oil so he thought there would be an oil leak, so I'm wondering if the oil light is on because it's down a quart or so.
Thanks.
Old Oct 30, 2016 | 01:19 PM
Pulling the dip stick and checking the level would answer your question.
Old Oct 30, 2016 | 01:23 PM
kmwise97's Avatar
kmwise97
I'm sorry I was unclear, there is oil in it, it is low, to me it seems natural that the light would be on, however my step-dad was concerned it might be an oil leak.
Any idea on the shaking?
Old Oct 30, 2016 | 01:39 PM
Shaking is motor mounts. Check underneath if you suspect a leak.
Old Oct 30, 2016 | 01:48 PM
kmwise97's Avatar
kmwise97
Thanks man!
Old Oct 30, 2016 | 02:07 PM
You could also add oil to bring it to the proper level and see if the light goes out. Otherwise, it could be a sensor and/or oil pump issue.
Old Nov 1, 2016 | 01:26 PM
darthroush's Avatar
darthroush
Section Moderator
Common for the motor mounts and oil pressure sensor to go bad.
Old Nov 1, 2016 | 01:27 PM
darthroush's Avatar
darthroush
Section Moderator
Look here too: Buying a used Neon? What to look for...
