Brake problem - need advice
Old 05-12-2004 | 07:30 PM
Robbiesan's Avatar
Robbiesan
Default Brake problem - need advice
Hi all. I'm new here. I hope some of you can help me out.
I have a 97 Neon DOHC that I picked up about 8 months ago. Recently my front left brake has started acting up.
Symptom - caliper releasing slowly and dragging often
Temp fix - slamming on the brakes a fews time helps to get the fluid flowing properly
My bro and I thought it might be the caliper so we replaced it. The problem still existed. My brother tried locking the brakes which had a positive affect of allowing the caliper to release properly (noted above). This was okay for a few days then the slow release problem came back.
I noticed the fluid was quite dirty and had not been changed in a a long time. I took it to a shop for a power flush. Once again the problem disappeared and I hoped it would not come back. But it has happened again.
I am thinking it may be the proportioning valve that is the problem but not sure. A tech said he would replace the brake hose as the next step thinking it could collapsed inside. But, if this were the case would the problem be intermittent? Sounds liek a collapsed hose would keep the release problem a permanent thing.
Has anyone run into a problem like this? Any advice you can offer would be appreciated.
Old 05-13-2004 | 08:01 AM
71RoadRunner's Avatar
71RoadRunner
Default RE: Brake problem - need advice
I haven't had this problem before, but it could be the hose. It's the easiest fix also. Check for any kinks in the hard lines. I am more for your idea, that it's the proportioning valve. It could be as simple as a particle that is stuck in it not allowing it to bleed off properly.
Old 05-13-2004 | 03:12 PM
Robbiesan's Avatar
Robbiesan
thanks for the reply 71RoadRunner.. I think I'll try pulling out and cleaning the proportioning valve first (despite it being more work).. I'll save the brake hose replacement for now thinking that a collapsed hose would inhibit fluid flow in both directions completely until replaced.. it just seems like the back flow is disturbed temporarily and a power braknig session clears it up.. I'll let you know how it goes..
Old 05-14-2004 | 06:10 AM
71RoadRunner
Thats how I figure it, a problem in it. We'll be waiting to hear from ya'.
Old 05-15-2004 | 01:23 AM
JCswm's Avatar
JCswm
Get the LF wheel off the car
push the brake pedal down and release
can you turn the rotor????
if NO open the brake bleeder
If a little fluid came out and/or you can now turn the rotor REPLACE THAT HOSE!!!!
It's like a $12.00 hose that's easy to install
Let me know how that turns out!!
Old 05-25-2004 | 07:14 PM
Robbiesan's Avatar
Robbiesan
Yep, you called it.. replaced the brake hose and all is well.. never run into this before but it all makes sense now.. thanks for your help guys...
