no brake lights
Old Feb 25, 2006 | 10:16 PM
rhinozhorn's Avatar
rhinozhorn
Default no brake lights
Hello all. I am new of coarse, but I have a problem with my 98' neon. I seem to not have my brake lights, except for my upper 3rd light which works fine. I have checked all my fuses and my blinkers and running lights work just fine. Any one have a clue what the problem is? Brake light switch or turn signal switch?? I am stumped at the moment. thank you..
Old Feb 25, 2006 | 10:50 PM
highline95jl's Avatar
highline95jl
Default RE: no brake lights
There are two bubls that run the break and turn signal system. Change them both on both lights and you should be ok.
Old Feb 26, 2006 | 01:48 PM
rhinozhorn's Avatar
rhinozhorn
I wish changing the bulbs would be that simple, the bulbs are fine. Thats one of the first things I checked.
Old Feb 26, 2006 | 11:14 PM
highline95jl
well its probably your light assembly then. Theyre about 20 bucks a pop at the salvage yard.
Old Feb 27, 2006 | 01:45 AM
casper's Avatar
casper
Have you checked the brake switch at the pedal? Its rare but possible.
Old Feb 27, 2006 | 03:13 AM
rhinozhorn's Avatar
rhinozhorn
well, it is either the brake light switch or I have heard maybe the turn signal switch? I have tested the taillights with a light tester and found no power to the bulbs, so could it be the switch or a break in the wire? The 3rd light works as well as the running lights. I have to track down the feed to both the brake lights.
Old Mar 6, 2006 | 03:28 PM
kvnband's Avatar
kvnband
If it were the brake switch, you wouldn't be getting a third brake light. So you can rule that out.
Old Mar 6, 2006 | 03:54 PM
musclecarneon's Avatar
musclecarneon
The bulbs have two filaments inside one is kind of down lower so it's hard to see. Did you make sure both filaments inside the bulbs work?
