ACK water in my trunk!!
Old 03-20-2006 | 10:47 PM
acid_mojojojo's Avatar
acid_mojojojo
Default ACK water in my trunk!!
So a friend asked me for a tire iron today. I went to grab teh one out of my wheel well. And what do I find?? Standing water in there. The rest of the trunk is dry as can be, I can not even find a small trail down. Does anyone know what could have caused this? (Yes it did rain very hard this past weekend, but the car was parked in teh driveway and not driven) And what can I do to fix it?
TIA
mojo
Old 03-21-2006 | 12:14 AM
spudsterier's Avatar
spudsterier
Default RE: ACK water in my trunk!!
the water comes from behind the tail lights, what works good it to get another set of the foam gaskets and double them up
Old 03-21-2006 | 01:06 AM
acid_mojojojo
is that problem even on the second gen cars??
mine is a 2003
Old 03-21-2006 | 02:05 AM
spudsterier
as far as i know it is... all neons have that problem
Old 03-22-2006 | 04:30 PM
musclecarneon's Avatar
musclecarneon
That same thing happened to me last time I took the tire out to check it the well was all sticky and full of crap. I just used duct tape to seal things up and it's fine now, but don't leave it or your well will rust out.
Old 03-22-2006 | 06:07 PM
spudsterier
i got tired of the water sitting in there so i drilled a couple small holes in the well for it to drain out...i had one of my cars sitting outside all witer long and when i removed the tire there was a huge ice chunk in there, so once it got warm i put a bucket under the car and drilled the wholes, removed 6 gallons of water from in there, plus had to get new carpet and tire cover because of mold...
Old 03-22-2006 | 09:10 PM
acid_mojojojo
Yes I had a 97 Neon with the same problem, and I drilled 2 holes inteh bottom of that one. Was hoping that a) they had fixed the issue and I would not have to worry, or b) there was a better fix. Oh well
Old 03-24-2006 | 08:09 AM
Arita's Avatar
Arita
I thought it was a dodge problem in general....I've never owned a dodge with a dry trunk
ORIGINAL: spudsterier
Old 03-24-2006 | 03:36 PM
highline95jl's Avatar
highline95jl
Thats funny, my car has never had the leakage problem. I know nothings been done to correct it considering the car has been in my family, in my house even since I was 5 or 6 or however old I was in 94
