Nitrous 4 my Neon....
Old Apr 2, 2006 | 03:31 PM
Matt_92988's Avatar
Matt_92988
Default Nitrous 4 my Neon....
Ok, heres the situation my neon is pretty much stock except for a cold air intake and high flow muffler. Should I finish with all the bolt on parts like header, high flow cat, under drive before i get nitrous?
I was thinking about a 50 HP shot would do, what do you guys think?
Old Apr 2, 2006 | 03:34 PM
highline95jl's Avatar
highline95jl
Default RE: Nitrous 4 my Neon....
Your taking a big risk with Nos, especially if you dont have new aftermarket internals. Id get some more bolt ons, and do some serious motor work.
Old Apr 2, 2006 | 04:33 PM
ugotit's Avatar
ugotit
I would go with more bolt ons until your ready to go though the motor .
www.strippermotorsports.com
866-708-7744
Old Apr 3, 2006 | 09:49 AM
RadarLove's Avatar
RadarLove
How many miles are on the car? How familiar are you with nitrous setups? A 50 shot is doable, but I'd start lower and work up, using a dyno w/wideband to tune...
Best of luck!
Old Apr 4, 2006 | 01:20 AM
Matt_92988's Avatar
Matt_92988
ive got about 55,000 on it
Old Apr 4, 2006 | 02:14 PM
RadarLove's Avatar
RadarLove
A well thought out nitrous setup can be a great bang for the buck. I presonally don't care for the NOS setup, I like the Nitrous Express deal with the GenX safety stuff. Even though it says you don't need it, a better fuel pump (Walbro 255 lph) is a great idea, as is a timing retard unit like the MSD DIS-2. With all that, a clutch that can handle it, and some time at the dyno, a 75 HP shot would get you farther than bolt-on's ever will, and only run $1500-2000 or so. With the progressive controller and serious dyno tuning (along with the fuel pump and timing reatrd, of course), you could run a progressive 100 HP shot - it's already been done on the stock bottom end... reliably...
But for now, a 50 shot, and bolt-on's as they come will probably do fine. If you think $1500 is too much to spend for a measly 50-75 HP, you haven't priced how much it would take to get your motor to 200ish HP naturally aspirated... I could do it for about $8k, stock to finish... Frankly, a $3000 turbo kit would be the way I'd go if I had it to do all over again.
