Help! My Trunk Rattles so Loud!
Old Jul 13, 2006 | 04:09 PM
spudsterier's Avatar
spudsterier
Default RE: Help! My Trunk Rattles so Loud!
nice thing about dynomat is that you dont have to prepare the surface at all....they say to use a hair dryer and a roller....heat up the mat, stick it on the trunk and roll it flat.....i just stuck mine on there and it would without any problems.....
i used some GREAT STUFF foam sealer on mine too....i filled up all the holes and cracks in the lid with it...then put duck tape over the holes so that the foam doesnt leak out...then when it dried i put the dynomat on everything....then sprayed the underside of the lid down with rubberized undercoating.....because i didnt want that aluminum foil look when you pop the trunk...plus i had 4-12's in the trunk in single boxes....so i needed sumthing a little extra
Old Jul 14, 2006 | 12:07 AM
Drunkship's Avatar
Drunkship
So you are saying just put it directly onto the latch? The latch is like not even 3 inches wide.
Old Jul 14, 2006 | 09:47 AM
spudsterier
not just the latch but yeah....im just sayin to cover the latch
Old Oct 10, 2006 | 01:54 AM
Maxx's Avatar
Maxx
Spudsterier, wanna hook me up with a picture of your trunk so i can see what your talking about? im having a similer problem with the trunk of my neon rattling and i even moved down teh latch's 1/4 inch and still its harder to close but still rattles and i have 2 JL audio 12's in there.
Old Oct 10, 2006 | 09:31 PM
djmagic's Avatar
djmagic
With mine it rattles but it is most likely that little black plastic piece that is causing it.
Old Oct 24, 2006 | 05:21 PM
Meskin24's Avatar
Meskin24
You can also tighten the trunk so it is not as loose, I did this to mine and the dynomat. I have 2 15 Kickers.
Old Oct 25, 2006 | 04:13 PM
spudsterier
wow i never noticed the post about wanting the pic of my trunk.....i dont have a pic of that though since i havent had a stereo in my neon for a long time
