engine keeps stalling HELP!! PLEASE!!
Old Aug 15, 2006 | 02:59 PM
jenn78's Avatar
jenn78
Default engine keeps stalling HELP!! PLEASE!!
hello all, I have a problem with my 2002 (automatic)neon se. when I go to start up the car it starts for a second and then dies unless I keep giving it gas. I have been having to do the brake/tap the gas pedal whenever I'm at a stop just so the car won't stall on me. Then it seems after a while after it gets warmed up, it drives and idles normally. has anyone else had this happen? I've seen several possibilitys on what it could be,but I just don't know where to start,and I dont have the money to purchase too much. if anyone can help, it would be greatly appreciated.
Old Aug 15, 2006 | 04:41 PM
CA180's Avatar
CA180
Default RE: engine keeps stalling HELP!! PLEASE!!
have you given it a tune up? Changed the plugs? fuel filter? Does it make any noises? Could be alot of diff things.... Give me a little more info and i might be able to find out whats up,,
thanks, stephen
Old Aug 21, 2006 | 02:07 AM
NorthernR/T's Avatar
NorthernR/T
could be a vacuum leak or a dirty throttle body or a faulty or dirty Idle Air Motor
Old Aug 24, 2006 | 06:07 AM
NeonX143's Avatar
NeonX143
What about something with the Fuel filter?? Bad, or maybe damaged somehow????
