Oil Pan Change
Old Aug 22, 2006 | 02:59 AM
Goldeneyes's Avatar
Goldeneyes
Default Oil Pan Change
Hi everyone,
The Oil Pan on my girlfriend's 1995 Neon needs replacing. I found a diagram on the internet that makes the job look not too difficult, so I thought I'd try it myself. Are there any tricks to getting this thing on an off? I know with some vehicles, major labour is required to remove this item...
Thanks in advance!
Old Aug 22, 2006 | 11:57 AM
allspoolin's Avatar
allspoolin
Default RE: Oil Pan Change
yeah you may have to jack up the one side of the motor so the pan can clear the motor mount...goodluck!
Old Aug 22, 2006 | 03:39 PM
spudsterier's Avatar
spudsterier
just take off the front mount.....then you will have access to all the bolts and it can come out without any problems
Old Aug 22, 2006 | 07:20 PM
das2123's Avatar
das2123
Do what spud said and get a gasket scraper to get off all the old gasket material or you could spring another leak.
Old Sep 2, 2006 | 03:23 AM
ewetho's Avatar
ewetho
Just keep unbolting stuff and it comes out pretty easily no big deal at all. Clean up good ad reinstall new one with a fresh factory gasket and happy motoring.
