clunk
Old Aug 11, 2004 | 08:56 AM
tomt's Avatar
tomt
Default clunk
hi folks. i've a 2k with 78+k miles. i hear a "clunk" going over what i can only call "small, sharp" bumps. it sounds to me like strut bearings. anyone mess with them? i remember from my VW days that a spacer could be placed below the strut bearing retaining nut [ on the car repair]. anyone got info? thanks, tomt
[IMG]local://upfiles/3669/B2DB6710B3BC4535A99D0DA24FD55AFB.jpg[/IMG]
Old Aug 11, 2004 | 06:18 PM
casper's Avatar
casper
Default RE: clunk
could be bad struts, broken sway bar bolts, bad hub, any number of things
Old Aug 11, 2004 | 07:31 PM
b_s_d's Avatar
b_s_d
Default RE: clunk
The trunk lid can also make a noise over sharp bumps that sounds deceivingly like a rear suspension "clunk" if it is not adjusted tight enough against the seal.
Probably not the problem, but very easy to rule out.
Old Aug 13, 2004 | 03:03 AM
04dodgeneon's Avatar
04dodgeneon
Default RE: clunk
Can you narrow it down, is it coming from the front/rear, passenger/driver side? It's still gonna be hard to tell though.
Old Aug 15, 2004 | 07:34 AM
darkchallenger's Avatar
darkchallenger
Default RE: clunk
Could be something with the trunk if your sound is at the rear. I asume from your pic that you own a Gen 2 Neon as I do. That sound is common in rear when I pass over speed bumps in my neighborhood if something laying in my trunk loosely. Not sure if in the area of loose lid though as I just had mine totally replaced right down to the body panel due to woman mashing me in the rear with her e'02 Dodge Durango.
Old Aug 17, 2004 | 12:09 AM
dvgRT's Avatar
dvgRT
Default RE: clunk
Welcome to 2nd gen Neons!
Old Aug 17, 2004 | 06:25 PM
verhagem's Avatar
verhagem
Default RE: clunk
I don't think it's just the 2nd generation Neons that are plagued with noisy trunks. My '98 makes a lot of noise back there too. If it's a rattle in the front end and you do end up solving it let me know. I've been chasing a rattle in the passenger's side front of my car for a year now. I'm fairly certain that it is coming from the caliper, but I can't figure out where or why. Pads aren't loose. I threw a new set of caliper bushings at it, which seems to help a bit, but it's still there.
Old Aug 17, 2004 | 07:10 PM
LoNeWuLf's Avatar
LoNeWuLf
Default RE: clunk
ME TOOOOOOO!!!!!
Old Aug 18, 2004 | 03:47 PM
casper's Avatar
casper
Default RE: clunk
I have a 98, I have the same passenger side thump, I know this may sound stupid, but I think mine is my windsheild, I had the noise got the windsheild replace and it went away. mine was more of an interior noise though.
