Window Crank Handle 95 Neon - HELP PLEASE!
Old Aug 13, 2004 | 02:05 AM
acosja2004's Avatar
acosja2004
Default Window Crank Handle 95 Neon - HELP PLEASE!
Hello!
I am trying to remove the inside door panels so that I can remove my speakers in the front driver and passenger doors. I have everything off, the clips snapped off easily, and I unscrewed the two screws that go with the door handle, and the door panel is loose, however, I can't seem to get the damned window crank handles off!! I thought they would just snap out, or unscrew, but I can't seem to get them off no matter what I do. It is probably really simple. Do I need a special tool? I don't want to force the issue because I'm afraid I will snap them off. Any help would be appreciated! Thank you!! Please e-mail me at acosja2004@yahoo.com Thanks in advance again!!
J.
Old Aug 13, 2004 | 02:34 AM
b_s_d's Avatar
b_s_d
Default RE: Window Crank Handle 95 Neon - HELP PLEASE!
ORIGINAL: acosja2004
..... I can't seem to get the damned window crank handles off!! I thought they would just snap out, or unscrew, but I can't seem to get them off no matter what I do. It is probably really simple. Do I need a special tool?
There's a retainer clip on the back. Should be able to work it off with a flat piece of plastic or a stiff rag. I worked it under the hub from the crank side last time I removed one - but don't recall if it stays oriented that way. You can barely see the clip by pushing the door panel in around the ****. There is a cheap sheet metal tool that can be bought in most auto parts stores/departments that is handy for this, but not necessary.
