Headgasket Q's
Headgasket Q's
I've got a 1998 SOHC and it doesn't have the MLS headgasket. I already checked for the tab thing in between the intake runners. Is the headgasket covered under recall, or am I going to have to pay to have it replaced. I also think that the front struts are under recall. The car has less than 70000km, I don't know if that matters at all. Also when the headgasket is replaced, should the car be babied for a while, does it need to be broken in? If so for how long? TIA
RE: Headgasket Q's
ORIGINAL: 1998neon
Don't know if the situation described for the 95-98 headgasket at that site is still accurate, but the general info on how the auto manufacturers respond to potential class action problems is insightful. It was a help to me in getting the out-of-warranty headgaskets replaced on a Ford 3.8 V6 for which I was the original owner at about 70K miles.
RE: Headgasket Q's
Hey, that's kinda funny. The only Ford our family has ever owned blew it's 3.8 Taurus headgasket at about 60,000. About 6 weeks ago my father and I toured a pick n' pull that was litered with Taurus' and they all had their engines in them--we joked about them all blowing gaskets. . . . they were very common.
About break in--only if you're replacing a bearing/ring surface--cam, rings, main bearings etc would it be an issue--and mostly the way the cam wears in is the biggest issue. No worries.
. . . but. . . if you're gonna pay and do it yourself. . . wouldn't you like to spend just a little more on a Crane Cam. . .nyuk yuk yuk.
RE: Headgasket Q's
ORIGINAL: red91RT
RE: Headgasket Q's
ORIGINAL: 1998neon
Since my car is 6 years old, am I going to have to fork out money to pay for the gasket and shop time? I just picked it up, the previous owner should have done it. Is there any way to not pay for it?
When the Ford dealer confirmed our headgaskets were bad, they waited to see if we'd just cave and eat the cost. I asked to talk with the service manager about the special program that I had heard was being discussed. He confirmed it and agreed to fix it at no cost to us. Later he told us that he had just gotten authorization that week to cover those repairs - so luck in timing can be key. Ford didn't send their letters out for another 4 to 6 months.
I suspect you're going to have to eat the cost.... at least for now, with some slim hope that enough pressure is eventually put on Chrysler to produce some compensation in the future. I believe there is now a law firm pursuing a class action suit. A google search on "neon headgasket class action" will probably turn up a firm name and/or number. You can check with them for status and if you even qualify for the class as a 2nd or 3rd owner. Who knows, Chrysler may even be marginally more responsive if they suspect you're considering joining the class action.
If you do chase this, let us know what you find and how you make out. Good luck!
Trending Topics
RE: Headgasket Q's
ORIGINAL: 1998neon
RE: Headgasket Q's
ORIGINAL: b_s_d
Yep... it's not a problem, it's an opportunity to upgrade [sm=smiley18.gif]
ORIGINAL: red91RT
In fact, I told my wife recently I'm never changing her oil because I want her to wear out the 5.7 in her suburban so I have an excuse to get one of the smog legal 383 stroker blocks GM makes now. LOL! She didn't like that idea much.
RE: Headgasket Q's
ORIGINAL: red91RT
