Tranny
Old Feb 10, 2007 | 03:05 AM
djmagic's Avatar
djmagic
Default Tranny
I'm planning on a SRT-4 swap but I'm trying to keep it auto with the PT Crusier auto tranny, it bolts up fine butcan it handle 350-450 HP?
Old Feb 10, 2007 | 02:12 PM
Jr. Mechanic's Avatar
Jr. Mechanic
Default RE: Tranny
Im sure it would handle the power, but why would you want to keep it auto? You can get ALOT more out of your engine if you use the 5spd MTX
Old Feb 11, 2007 | 03:38 PM
djmagic's Avatar
djmagic
Default RE: Tranny
I'm not great at stick.
Old Feb 12, 2007 | 02:02 PM
das2123's Avatar
das2123
Default RE: Tranny
ORIGINAL: djmagic
LEARN!
The PT tranny may bolt up, but you are gonna have fitment and heat problems in the small 1st gen engine bay.
Old Feb 13, 2007 | 01:28 PM
Jr. Mechanic
Default RE: Tranny
[&o]
Old Feb 13, 2007 | 01:30 PM
Jr. Mechanic
Default RE: Tranny
ORIGINAL: das2123
ORIGINAL: djmagic
LEARN!
LoL. Well, If heat is the problem, I would just get a cheap tranny cooler at the parts store, but I still would go with the 5spd manual. Trust me, it is not really worth doing a srt swap with an auto tranny, you lose too much with that combo.
Old Feb 13, 2007 | 02:23 PM
das2123's Avatar
das2123
Default RE: Tranny
ORIGINAL: Jr. Mechanic
Won't work anyway. Thats why the 1st gen neon came with the 3-spd. Chrysler experimented with a 4-spd but heat was the problem.
An SRT-4 engine bolted up to the 1st gen ATX isn't a bad idea, just need to have the tranny built up. Nothing like holding down the brake and gas and already be in boost when you let off the brake.
Old Feb 13, 2007 | 09:35 PM
djmagic's Avatar
djmagic
Default RE: Tranny
First of all it is a 01 which is a 2nd gen. Also I would rather learn in someone else's car instead of in my baby.
Old Feb 13, 2007 | 11:34 PM
malcolm_318's Avatar
malcolm_318
Default RE: Tranny
stick is easy man.....i found it hard at the start but i just drove around for about an hour one night so no one seen my screw ups and i picked it up like a snap.
Old Feb 14, 2007 | 12:28 AM
das2123's Avatar
das2123
Default RE: Tranny
ORIGINAL: djmagic
The 01 still has the 3-spd ATX because if heat issues!!!!!
