09 dodge nitro no start, no crank
Driving down the HWY at HWY speeds my 09 nitro just died, after 3 months it still won’t start Turn key and all accessories turn on and batt Is good. But no turn over at all. The fuse box relays click when key is in "on" position, but no start or crank. I have tried to read codes and it says communication error or something like that. I have tried my other key still nothing. I have noticed that my red security light is flashing now then does solid. Please help this is getting very frustrating
ENGINE WILL
NOT START
1. Weak battery 1. Charge or replace
as necessary.
2. Corroded or loose
battery connections.
2. Clean and tighten
Apply a coat of
light mineral grease
to the terminals.
3. Faulty starter. 3. Refer to
DIAGNOSIS AND
TESTING .
4. Faulty coil or
control unit.
4. Refer to
REMOVAL .
5. Incorrect spark
plug gap.
5.
6. Incorrect right
bank cam timing.
6. Refer to engine
timing in this
article.
7. Dirt or water in
fuel system.
7. Clean system and
replace fuel filter.
8. Faulty fuel pump,
relay or wiring.
8. Repair or replace
as necessary.
9. Faulty cam or
crank sensor
9. Refer to Ignition
system.
NOT START
as necessary.
Apply a coat of
to the terminals.
DIAGNOSIS AND
TESTING .
4. Faulty coil or
control unit.
4. Refer to
REMOVAL .
5. Incorrect spark
plug gap.
5.
6. Incorrect right
bank cam timing.
6. Refer to engine
timing in this
article.
7. Dirt or water in
fuel system.
7. Clean system and
relay or wiring.
as necessary.
9. Faulty cam or
crank sensor
system.
