Dodge Nitro The Dodge Nitro is a sporty mid size SUV that bound to turn heads where ever it roams. The Dodge Nitro is one fun ride!
2007 Nitro R/T #5 Misfire
Old Feb 17, 2020 | 08:41 AM
superdak05's Avatar
superdak05
Default 2007 Nitro R/T #5 Misfire
186000 miles on truck. 100000 miles had complete tune up and timing change done, now every now and then a misfire is happening, pulled apart intake because thermostat needed change, new coil, plug but noticed that when our remote start was installed back in 2007 they plugged into #5 coil power. Very rarely we use the remote start, could there possibly be a short somewhere? or should we just cut the power wire to the remote start and see if the problem goes away. were not losing fluid and no white smoke upon start up.
Old Mar 6, 2020 | 12:34 PM
master tech's Avatar
master tech
Site Moderator & Tech
I would disconnect the remote start and see if there is any change. I would also switch the injector from number 5 to number 3 and see if the misfire follows to number 3.
Old Apr 10, 2020 | 08:30 AM
superdak05's Avatar
superdak05
Thank you for the input, swapped out the injector and issues went away, noticed a little black soot mark on original injector. plugs still looked brand new
