Dodge Pro Master The Dodge Pro master is all function, with styling cues from the Dodge Truck line, it makes the workaholic's job much easier. Check out the Dodge Pro Master in showrooms today!
1996 dodge b2500 V8 part question
Old Sep 4, 2020 | 01:13 PM
J Mas's Avatar
J Mas
Default 1996 dodge b2500 V8 part question
So this part ripped off last jight and amoke everywhere. The smoke was due the coolant spraying everywhere cause a hose ripped. But inside the hose was connected, (originally or after market, i dont know), by plastic to this part. I tried the worst 5 year old tape and glue job with what i had to get me to oreillys to buy the part. The mechanic is no where to be found and the employess are as stumped as I am. Meanwhile i decided to see if I could get some really quick help from some actual experts, while i sit in the parking lot. I hope i can add pics as a newbie, if not ill figure something out. Thanks in advance!
This is before i took it apart obviously. All the way in the back passenger side
This is the hard plastic part
The hose. These are just last night. I can take more pics of it if need be, but im telling you, I did a slap *** job with the glue...
Old Sep 4, 2020 | 02:13 PM
Flow control valve. Keeps coolant from running thru the heater core if you aren't actually wanting heat...... Parts store should have new ones on the shelf.
