Towing Problems
Old Apr 14, 2007 | 08:07 PM
  #21
Drew's Avatar
Drew
Default RE: Towing Problems
ORIGINAL: Mayfair
ORIGINAL: Cumminnotstrokin
Check your exhaust manifold my brother-in-law had a similar problem turned out that his manifold was cracked.
Does "checking it " simply mean just looking at it for obvious cracks, or are you hearing some sort of exhaust leak from it while the truck is running?
essentialy. . .you would see exhaust shooting out if there was a hole
Old Apr 15, 2007 | 01:30 AM
  #22
R0oster31's Avatar
R0oster31
If the manifold was cracked and he was loosing boost wouldn't he be smoking? I'd check that fuel pressure...a new injector pump is expensive.
