Fuel pressure gauge
RE: Fuel pressure gauge
ORIGINAL: Mayfair
I guess if i saw the instructions I'd understand better, but what's with the antifreeze? Do you mix it with the fuel or something? I don't get how the two mix.
I've only been here for a short time and I'm not trying to be an ***, but these guys must really have a lot of patience for you. [sm=lol.gif][sm=lol.gif][sm=lol.gif]
ORIGINAL: GFB
[sm=headbang.gif][sm=headbang.gif][sm=headbang.gif]
ORIGINAL: Mayfair
we dont go off on him cause he supplies us with pics of Scarlet Johansens stacks[8D]
ORIGINAL: GFB
Besides, if everybody here knew everything about anything, what the hell would be the discussion.
You know we love ya brotha!
ORIGINAL: cumminalong
Soooooo, with that being said ..... What's the antifreeze for ??
ORIGINAL: Mayfair
Pfft .... I aint sweatin that cat. I don't recall ever stating that I'm an Einstein, or that I knew everything. I'm here to learn, hang out with some friends, and have fun while doing so.
Jokers Wild ! Mayfair, you da man ^>^
The anti-freeze is just a non flammable, safe ( as long as you don't drink it ) fluid to use instead of fuel. The last thing you need is a fuel leak in the cab.
The isolator is a rubber diaphram that separates the fuel from the anti-freeze. The fuel side of the isolator connects to either a tapped fuel filter cap, using a banjo bolt on the CP3 or, installing a T in the fuel line. When the pressure from the pump hits the diaphram it transfers the pressure to the anti-freeze side. That in turn pushes the anti-freeze to the gauge to to show your pressure.
ORIGINAL: triton
GFB - Thanks to you too for helping to clear things up !! I knew you were havin fun.
