Throttle stuck
Old Apr 20, 2007 | 08:26 PM
mudder500's Avatar
mudder500
Default Throttle stuck
I was playing around at work blowing smoke on my bosses car and the throttle stuck at 4 grand. Shut it off and everything went back to normal. Anyone esle have this happen?
Old Apr 21, 2007 | 01:01 PM
bisonboy02's Avatar
bisonboy02
Default RE: Throttle stuck
I had this happen to me on my 05 ctd. If the truck was idling andyou stepped on the throttle to bring up the rmps the engine would take off to 3500-4500 rpms and surge. I took it to 2 dealers and they could not find the problem, they changed fuel filters, flashed the ecm, etc...
I had to drive 6hrs to a rep. dealer and they fixed if. They replaed all 6 injectors.
I am not saying this is your problem, but it my be something to look at.
Old Apr 21, 2007 | 02:49 PM
cmnspwr's Avatar
cmnspwr
I was reading on this a while back and the most common problem that I found was that the floor mat mashed the pedal down. Are you sure this wasn't the problem?
Old Apr 21, 2007 | 05:32 PM
DieselDemon's Avatar
DieselDemon
If you have a 94, 95, or 96 they had MAJOR problems with the throttle cable freying. It would get pulled into the cable's sheath, and then get stuck. It was a big problem back in the mid 90's
Good luck with your ride.
Old Apr 24, 2007 | 05:16 PM
mudder500's Avatar
mudder500
i dont have floor mats. my buddy works at dodge and came today with an 05 to show me and it was sticking at 2 grand. he hasnt heard of it till now
Old Apr 24, 2007 | 05:26 PM
Drew's Avatar
Drew
if I put my foot into the throttle on mine she'll hit 32-3500rpm then slowly back down. this is common on HPCR's since the fuel rail is highly pressurized with fuel and it takes a bit for the injectors to bleed this back down especialy under a loaded high boost condition.
Old Apr 25, 2007 | 07:28 PM
mudder500's Avatar
mudder500
thanks that would explain why it only did it with crazy larry sitting
Old Apr 25, 2007 | 07:48 PM
Mayfair's Avatar
Mayfair
ORIGINAL: mudder500
