check engine light
Old Apr 22, 2007 | 10:37 PM
Hiloram's Avatar
Hiloram
Default check engine light
My check engine light is staying on. Can anyone help me with the procedure to check what codes it throwing.
thanks
Old Apr 22, 2007 | 10:49 PM
FroneDaddy's Avatar
FroneDaddy
Default RE: check engine light
Cycle the ignition 3 times on & off, the third time leaving it in the on position. The code will be displayed where your mileage is
Old Apr 22, 2007 | 10:56 PM
Hiloram's Avatar
Hiloram
P00071
I know somebody posted the codes awhile ago but a don't know what I did with them
Old Apr 22, 2007 | 11:00 PM
FroneDaddy's Avatar
FroneDaddy
You must have looked at it wrong, the lowest code is P0100, try it again
Old Apr 22, 2007 | 11:05 PM
Hiloram's Avatar
Hiloram
just checked again. P 0071
I put in one to many zeros
Old Apr 22, 2007 | 11:07 PM
FroneDaddy's Avatar
FroneDaddy
And this is on your '06, that sounds like a 1st or 2nd gen code
Old Apr 22, 2007 | 11:11 PM
FroneDaddy's Avatar
FroneDaddy
Has to do with your inlet air temperature sensor rationality, there is a TSB for it. Check this out
TSB 18-022-06. All it takes is a re-flash at the stealership.
Here is the TSB http://dodgeram.info/tsb/2006/18-022-06.htm
Old Apr 22, 2007 | 11:13 PM
jakebrake's Avatar
jakebrake
NOOOOOOOOO[sm=violent053.gif]
[sm=ummmmokay.gif]
Old Apr 22, 2007 | 11:14 PM
Hiloram's Avatar
Hiloram
Thanks for the help!!
