which one?
Old Apr 27, 2007 | 03:23 AM
Collinlancaster's Avatar
Collinlancaster
Default which one?
lift pump is out,big surprise.should i go with the 95gph or the 150gph fass?
Old Apr 27, 2007 | 03:55 AM
CutterW's Avatar
CutterW
Default RE: which one?
How much added HP do you have? if just few mods just go 95gph but if your pushing around 500+ go 150gph Might be more than 500+
Old Apr 27, 2007 | 04:05 AM
Collinlancaster
no major mods.maybe a bigger turbo to keep the e.g.t.'s down better and 5inch stacks.
Old Apr 27, 2007 | 10:49 AM
Drew's Avatar
Drew
the 95 should do you fine. . .but if your planning some major mods in the future you may want to look into the 150
Old Apr 27, 2007 | 02:16 PM
Mayfair's Avatar
Mayfair
ORIGINAL: Drew
Dead on Drew !!
If you're still pretty stock, get the 95. If you are now, or your planning on bombing your truck in the future, get the 150. They don't reccomend getting the 150 for a stock truck because the FASS may die an early death, so use your head when deciding.
Also, I'd go with the larger of the two FILTERS.
This is where is can get confusing.
You'll see 95/95 and 95/150. They make a shorter fuel filter and they call them "95's". The taller filter ( the one that has been the typical FASS filter ) is called the "150". Therefore the first number above, the 95/95 would be the 95gph pump with the short filters. The second pump 95/150 would be the 95 gph pump and the standard taller filters.
I just learned most of this within the last few weeks and I've just installed a FASS last weekend, so if you want to know anything ask me NOW while it's still fresh in my mellon. Once the weekend passes and I have one too many brew-ha-ha's, I'm sure that info will be purged to make room for new.
Old Apr 27, 2007 | 07:52 PM
cookie_monstr's Avatar
cookie_monstr
wat u mean by early death. the pump is to much for ur app it dies? that doesnt sound right.
Old Apr 27, 2007 | 07:58 PM
Mayfair's Avatar
Mayfair
I don't know how to really explain it, but they ( the FASS people ) say that using the larger FASS may eventually burn it out. I don't know why or how, but I followed their advice since they know more than I do. It was also written up that way in a TDR magazine that I read a little while ago.
Old Apr 27, 2007 | 08:05 PM
cookie_monstr
mmm....thats strange...
Old Apr 27, 2007 | 08:18 PM
timesublime's Avatar
timesublime
Makes sense really, you would be operating the 150 in the lowest capacity. Therefore it would probably be bouncing of its pressure regulator, which hammers on your pump assembly. If the truck was mostly stock the 95 would be purring along suppling fuel without the hammer effect.
Old Apr 27, 2007 | 11:08 PM
jakebrake's Avatar
jakebrake
If you get the 150, you'll want to get a new fuel pickup tube because the stocker won't flow that much fuel.
