Finally found and installed - rear brake guards
Old Apr 30, 2007 | 07:18 PM
  #21
steve05ram360's Avatar
steve05ram360
Default RE: Finally found and installed - rear brake guards
the rears are probably overkill. when I priced them out for my 2000, the difference was $30~40 bux for everything. with that said, why not? turned out to be an awesome swap!
Old Apr 30, 2007 | 08:05 PM
  #22
Batphreak's Avatar
Batphreak
Never heard of a Crosley?
http://en.wikipedia.org/wiki/Crosley
Actually, if more stopping power is what you want Drum brakes have much more power than discs, and the really old constricting band brakes are even better than drums. All has to do with more friction area per brake size, discs are really in-efficient when it comes to friction area. The BIG upside to discs is that they can stop you more than once before they get to hot and fade away. Drums and bands are REALLY bad at getting rid of heat. Just letting you know, pure stopping power is not the reason discs are better (this goes for front and rear). Another benefit to discs is that they don't mind getting run through the mud and stuff as much, not too many places for grim to collect, drums have a tendency to hold mud and stuff inside them if they get dunked.
Old May 1, 2007 | 01:26 AM
  #23
jakebrake's Avatar
jakebrake
If disks sropped better, you would see them on semi's. You can't get enough friction area on them to stop that big of a load.
Old May 1, 2007 | 01:46 AM
  #24
MarkRAM01's Avatar
MarkRAM01
I have 76,000 on mine and more than 1/2 of the pads are left on the rear. My 3/4 ton with 4-wheel discs stops better than my 98 1/2 ton I used to own.
Old May 1, 2007 | 01:24 PM
  #25
racerpete's Avatar
racerpete
MAYFAIR !
I can't believe you didn't recognize a Crosley ! Come on Man, 44 CID, 26.5 HP, 4.80x12 Tires, and 55 MPG, What A Rush !!
Just kidding, by the way, I know your from Philly, I'm from the Jersey Shore, but I've also got a summer place just west of Cabalas of 22/78.
Old May 1, 2007 | 02:28 PM
  #26
timesublime's Avatar
timesublime
I tried the links to get a pair, but your site only does wholesale. Where can I get a pair?
Old May 1, 2007 | 02:55 PM
  #27
Mayfair's Avatar
Mayfair
ORIGINAL: racerpete
I've been to that Cabellas. That place is HUGE !!! I can't believe you leave the shore to vacation up the mountains. That's WHACKED !!!
What shore??
Old May 1, 2007 | 03:19 PM
  #28
tdmopar59's Avatar
tdmopar59
I love cabelas im there a lot my buddy's uncle has a place 10 minutes away from cabelas and we always go there its not to far off 78 couldnt tell you the exact location but cabelas is in hamburg right on 78
Old May 1, 2007 | 10:30 PM
  #29
jh's Avatar
jh
ORIGINAL: timesublime
I got mine at California Creations (located in Saskatoon, Saskatchewan - go figure). They don't have a web site. The phone number is (306) 955-4446. I would guess that the web site that I posted would be able to give you the name of some US distributors but maybe they are not available down there as there isn't as much need with all the good highways. Anyways, hope this helps.
