Drivetrain shaking
Old Apr 30, 2007 | 12:10 AM
Silverline's Avatar
Silverline
Default RE: Drivetrain shaking
I have an allergic reaction to dealerships...that and if I can find something a little more heavy duty I'd like to since we're probably keeping the truck for awhile.
Old Apr 30, 2007 | 02:59 PM
FroneDaddy's Avatar
FroneDaddy
Had the same problem with mine, at first the driveshaft there a weight which caused a slight vibartion and in turn tore the carrier bearing apart. new driveshaft and carrier bearing, was under warrant though.
Old Apr 30, 2007 | 09:32 PM
Kev_n_AZ's Avatar
Kev_n_AZ
NAPA or CARQUEST for the carrier bearing.
you might be able to order online also.
when you replaced the other u joints, did ya mark the shaft so it would line back up the same as before removal?
they are balanced. if the carrier doesnt do it, a tire balance and rotation wont fix it, have the drive shaft rebalanced.
