Turning Up A 12V Pump
Old Apr 30, 2007 | 12:13 AM
Silverline's Avatar
Silverline
Default Turning Up A 12V Pump
Was wondering if I had the procedure for turning up a 12V pump up right. Once you get to the starwheel in the pump you turn the starwheel so it turns toward the drivers side wheel. I remember hearing that you turn the wheel "towards" you, but that can mean either direction and I really don't want to screw this up since its a friends truck.
Old Apr 30, 2007 | 12:28 AM
Drew's Avatar
Drew
Default RE: Turning Up A 12V Pump
8mm allen head to remove the plug, then use a flat head screwdriver to turn it twards the engine. this will turn the fueling up. but be carefull, too much and you will roast the turbo from the EGT's. also if you slide the cam plate around you can increase the timeing of the fueling.
this PDF will show you alot http://www.tstproducts.com/INSRUCT98.pdf
Old Apr 30, 2007 | 12:31 AM
jakebrake's Avatar
jakebrake
so clockwise from the drive's seat?
Old Apr 30, 2007 | 01:14 AM
Silverline's Avatar
Silverline
That's my main problem too jakebrake. I can't tell which way to turn the thing.
Old Apr 30, 2007 | 01:22 AM
Drew's Avatar
Drew
basicaly take the screwdriver and push the top twards the engine. . .you'll feel it click.
Old Apr 30, 2007 | 01:24 AM
Silverline's Avatar
Silverline
Ok, I get it now. Any idea on how far you should turn it without risking burning up the engine.
Old Apr 30, 2007 | 01:29 AM
Drew's Avatar
Drew
does he have any gages???
no more than a few clicks
Old Apr 30, 2007 | 01:41 AM
Silverline's Avatar
Silverline
Not yet. He just barely asked me about it this morning and I was on my way out the door. I'm going to recommend at least a pyro if he does want to try it. He's not looking for a ton of power, just another 40 hp or so.
Old Apr 30, 2007 | 10:39 AM
Drew's Avatar
Drew
pyro and boost at a minimum. . .they are not hard to install
Old Apr 30, 2007 | 12:18 PM
Silverline's Avatar
Silverline
ok. Thanks
