S&B and K&N air intake kits???
Old May 3, 2007 | 11:38 PM
sonny t's Avatar
sonny t
Default S&B and K&N air intake kits???
Anyone useing the S&B or K&N air intake kits for the 5.9 2004.5 and up, I would appreciate any feed-back on either one or both of these intakes. I am planning on doing this mod soon and would like to know what to expect buy useing these products. The S&B claims to filter around 99.4 percent of the dirt particals, I am not sure what K&N is claiming. Any feed back is welcome, Thanks Sonny T
Old May 3, 2007 | 11:50 PM
Drew's Avatar
Drew
Default RE: S&B and K&N air intake kits???
for these engines. . .a filter with oil on it is asking for trouble. . .your best bet is to go with either a paper filter, amsoil nano, or the progrard or what ever it is called. . .
Old May 4, 2007 | 12:00 AM
sharx ram's Avatar
sharx ram
Iam running the S&B CAI and love it..no issues at all, so far.
Old May 4, 2007 | 01:13 AM
BLACKPearl06's Avatar
BLACKPearl06
I am also running the S&B so far so good. Gives the turbo a nice sound. And install was easy.
Old May 4, 2007 | 01:16 AM
rausch42's Avatar
rausch42
i have the aem brute force dry filter and absolutely love fast turbo spool, it's easy to clean, keeps dirt out, and the number one reason i like it no oil
Old May 4, 2007 | 04:33 AM
gtxpooch's Avatar
gtxpooch
Did I miss something? Why would an oiled air like K&N etc. filter cause problems?
Old May 4, 2007 | 04:37 AM
Kev_n_AZ's Avatar
Kev_n_AZ
ORIGINAL: Drew
so should I 86 the k&n on my 93 ctd?
Old May 4, 2007 | 03:17 PM
donnie's Avatar
donnie
I would say check the intake tube between the filter and the turbo.
If you have any indication of dust or dirt there, then dump the K&N.
I had a Airraid dropin and after 10000 miles, removed it for cleaning.
The prefilter pad on it had been sucked into the pleats.
Nothing made it to the turbo.
I dumped it and got a Amsoil dropin.
Truck seems to run better.
Old May 4, 2007 | 04:26 PM
Mayfair's Avatar
Mayfair
I've got a K&N on my 98. The truck definately breathes better, however I agree with the others and would reccomend a non oiled air filter. I clean my K&N every 5000 miles when I do an oil change, so I kinda know just how much oil to use, but if you over-oil it THAT'S when you could pull the oil through the filter and have some problems.
If I were you, I'd go with one of those monsters that Drew put on his truck. Keep it clean, and you'll be fine.
Old May 4, 2007 | 04:53 PM
rausch42's Avatar
rausch42
i also have a 99 ctd with the ho motor it has the k@n filter and it is nothing compared to the aem dry filter and tube im going to eventually change it over. The K@N usually is always dirty and is a pain to clean i clean it every oil change to
[IMG]local://upfiles/62128/9356EEA1CD3A4324A58C94AF4CFD5DE9.jpg[/IMG]
