Hour meter
Old May 8, 2007 | 11:51 PM
jakebrake's Avatar
jakebrake
Default RE: Hour meter
The ecm monitors all of that so the dealer can bring it up with a scanner/ reader. If you have too much Idle time the can void warrenty on the engine for things like scored cylinders, bad injectors, ect. I'm not sure how to display it on the dash though (3rd gens). I know that you can't bring this up with out a reader on the 2nd gen's.
Old May 13, 2007 | 11:27 PM
FroneDaddy's Avatar
FroneDaddy
OK, so I figured it out. I was doing it wrong, I was holding the odometer button and then turning the key to run, the correct way to do it is to turn key to run, make sure you are displaying the odometer (not the trip) and hold the button until it shows up. Looks like this.
[IMG]local://upfiles/57704/DB9D6EC5C4BC486FAED7D11A4BD3B7F5.jpg[/IMG]
Old May 14, 2007 | 02:44 AM
gtxpooch's Avatar
gtxpooch
Anybody know the correct way for 06's? tried it both ways, no workie.
Old May 14, 2007 | 12:22 PM
handymanherb's Avatar
handymanherb
Don't work on the 05, it just switches to trip
Old May 14, 2007 | 06:57 PM
FroneDaddy's Avatar
FroneDaddy
How long did you hold it? On mine you have to hold it for a good 10 seconds
Old May 15, 2007 | 01:17 AM
gtxpooch's Avatar
gtxpooch
I got it fingered out,I had to turn key to run with odometer showing then hold trip button down for about 10 seconds. 350 hrs, 14300 miles.
Old May 15, 2007 | 01:31 AM
jw_hendry's Avatar
jw_hendry
I have an 05, I can't get thehr's either, just goes straight to trip when pushed. When I hold it down, then turn on key, all the gauges go through their check, it says C code, then 64 07, then 00 00. What is it these numbers mean again?
Old May 15, 2007 | 01:34 AM
NickBeek's Avatar
NickBeek
You've averaged 40.857 MPH over the life of your truck.
Old May 15, 2007 | 01:36 AM
FroneDaddy's Avatar
FroneDaddy
ORIGINAL: jw_hendry
Read up a few, I just explained the correct way to do it.................
Old May 15, 2007 | 01:38 AM
NickBeek's Avatar
NickBeek
My numbers look like this 29238 miles 763 hours = 38.319 MPH average. Ok lets see who is the speed demon. Post your numbers.
