AC problems .... anybody know what this is ??
Old May 9, 2007 | 03:12 PM
handymanherb's Avatar
handymanherb
Default RE: AC problems .... anybody know what this is ??
You can't put on the wrong line as there are sized different , just follow the instructions, I wasn't up on A/C either till they wanted to take big money from me for a leak they couldn't find and the A/C quit the day after they looked at it.
I put in the stop leak and top off the 134a a few times over the next year and it still working
Old May 9, 2007 | 03:28 PM
Mayfair's Avatar
Mayfair
Ok guy's, I'll give it a shot this weekend.
Thanks !!
Old May 9, 2007 | 07:59 PM
Mayfair's Avatar
Mayfair
I'm going to Pep Boys tonight. Is this what I'm looking for ??
Old May 9, 2007 | 08:08 PM
Drew's Avatar
Drew
that stuff will work. . .however you do need to see if it will stop small leaks.
Old May 9, 2007 | 08:18 PM
Mayfair's Avatar
Mayfair
Do you think that's what I have ... a small leak? Is putting some sort of stop leak stuff in there ok to do? It won't hurt anything will it?
Old May 9, 2007 | 08:37 PM
FroneDaddy's Avatar
FroneDaddy
I breezed through here, but in caseI missed if someone answered it. That is your air dryer, it drys the air before entering the cab so you don't get wet. That shouldn't be frozen but it will get cold and drip a lot of water (condenation). Most likely low on freon.
Old May 9, 2007 | 08:38 PM
squirtbottle09's Avatar
squirtbottle09
You should have used a different color arrow. Lol, I looked for ever trying to find it, lol. But it is the same thing they all said above.
Old May 9, 2007 | 08:46 PM
Mayfair's Avatar
Mayfair
ORIGINAL: FroneDaddy
Thanks ... you're the first person who told me what the heck that thing is, although apparently the arrow color threw some peeps off. I suck with that paint program.
Anyway, yeah, it was frozen at the bottom. When I put my hand on it it was like holding an icecube. I guess that's what was thawing out in between my on/off cycles, I was waitin for that thing to thaw out.
Hopefully I'll be able to fix it tonight with that 134a stuff. Does it take long to do? I've neveradded freonbefore?
Old May 9, 2007 | 08:50 PM
FroneDaddy's Avatar
FroneDaddy
It's finally getting warm here in PA, huh Mayfair? I had mine on the other day too. Anyway, putting the stop leak in won't hurt, the pic of the can is good stuff. There are 2 port on a silver refrigerant line, one is the high side and one is the low side, the low side is where you want to put it, you can't get them wrong, the freon fitting from the can will only fit onto the low side they are 2 different sizes. The gauge is color coded, I believe yellow is where you want the needle to be. Some of the cans already have stop leak in them and other places sell separate cans of it. It's easier to buy one that already has it in it. That way you don't hit the green area with stop leak and never got a chance to put the freon in.
Old May 9, 2007 | 08:52 PM
FroneDaddy's Avatar
FroneDaddy
I don't know what the problem was, as soon as I scrolled down the arrow jumped right out at me. The longest part of doing this job is going to the storeand getting the freon. Once you get home it will take about 5 min.
