Manual tranny fluid change
Old May 15, 2007 | 08:42 PM
swilsone's Avatar
swilsone
Default Manual tranny fluid change
I just bought a used CTD with about 105K and I'm not sure if the 6-speed tranny fluid has ever been changed. I know that automatics are picky about oil...the old oil gums up and kinda holds things together if it isn't changed for a while. Then, if you decide to change it, you start having problems. I dunno about manual trannys, though. Anybody know if it'll start giving me trouble or if there is a good way to do this?
Old May 15, 2007 | 08:43 PM
swilsone's Avatar
swilsone
Default RE: Manual tranny fluid change
Sorry, it's a 2002 model.
Old May 15, 2007 | 08:46 PM
Mayfair's Avatar
Mayfair
I don't know diddly about tranny fluid in a manual trans, but WELCOME ABOARD !!!
Old May 15, 2007 | 09:03 PM
swilsone's Avatar
swilsone
Thanks, bro...I'm probably just over-thinkin this!
Old May 15, 2007 | 09:12 PM
JimmyDiablo's Avatar
JimmyDiablo
it is basically gear oil. could not hurt to change it if you are towing and putting a load on it, otherwise it is a manual transmission and you do all the work on it.
Old May 15, 2007 | 09:16 PM
swilsone's Avatar
swilsone
"I do all the work" ...as in instead of the detent *****, ports and stuff shifting gears? That seems pretty logical.
Old May 15, 2007 | 09:23 PM
JimmyDiablo
exactly. Might as well change the fluid as it will not be that expensive and then you can rest assured it is done.
Old May 15, 2007 | 09:25 PM
swilsone's Avatar
swilsone
Thanks!
Old May 15, 2007 | 10:25 PM
Drew's Avatar
Drew
amsoil 5w30 MTF. . .you cannot go wrong. it is specialy made for the NV5600.
Old May 15, 2007 | 10:56 PM
Super Dave's Avatar
Super Dave
I am thinking seriously about using the Royal Purple syncromesh (i think they call it). Anybody use it? I get a pretty decent price on it here on base.
