Autometer Gauges
Old May 17, 2007 | 11:47 PM
Ben D.'s Avatar
Ben D.
Default RE: Autometer Gauges
dude i bet that bright blue looks awesome. u need to get some pics at night with them lit up
Old May 18, 2007 | 12:04 AM
sharx ram's Avatar
sharx ram
There one in my photo gallery Ben...1st pic
Old May 18, 2007 | 02:16 AM
DieselDemon's Avatar
DieselDemon
AutoMeter......the only way to go. I personally chose the Cobalt line.
Old May 18, 2007 | 02:20 AM
sharx ram's Avatar
sharx ram
Nice Demon, hey what are the little dials or buttons on the lower left for?
Old May 18, 2007 | 02:29 AM
cookie_monstr's Avatar
cookie_monstr
digital dakota has digital guages. i like the way some look. u can color match and some other stuff. i personaly like the way thegauges over the rear view mirorr look.
Old May 18, 2007 | 11:10 AM
FroneDaddy's Avatar
FroneDaddy
I am going to be getting some gauges soon here, most likely the autometer phantom boost, egt & fuel pressure. My question, for each one, mechanical or electric. Also, I have been looking at their downloadable manauls and they aren't very detailed, so are they easy to install? EGT will be be a breeze, my concern is the boost & fuel pressure,what psi ranges shouldI haveand range for the EGT,and lastly besides boost & egt is the fuel pressure a good 3rd choice. Thanks
Old May 18, 2007 | 11:19 AM
sharx ram's Avatar
sharx ram
as far as installing them, I cant answer that question I had mine installed, I went with an electric fuel pressure to avoid having fuel run into the cab but mechanical on all others, if your truck isam auto?...if it is Id reccomend the tranny temp before the fuel pressure. JMO tho. good luck
Old May 18, 2007 | 11:41 AM
FroneDaddy's Avatar
FroneDaddy
What about blank covers, I am definitely getting a 3 pod pillar. However say I only buy2 gauges for now, do they sell a blank cover you can pop in there until you get another gauge?
Old May 18, 2007 | 03:23 PM
DieselDemon
ORIGINAL: sharx ram
Sharx......those are individual dimmers for each gauge. Each pot, (variable resistor), has a 10,000 ohm, 1 watt rating.One switch (not visible),mountedon the side of the pod shuts them off completely. When I first installed them, the briteness fused my rods and cones together.........LOL.
I keep them bright so when the smoke clears.............you can see them thru my back window. They are mounted in the center of the dash so both pilot and co pilot can monitor. Here's a pic. I'd show you a rear shot but I'd have to powder coat you first....lol,.....and I like your truck. Would hate to dirty it with unburned diesel.
j/k
I think it's a cool setup. Guys behind me see them and decide they want a closer look. I have no problem with smoke eaters.....LOL.
When I am cruising the back roads from PA to NY, I turn them down all the way so I can concentrate on the road. I'm not being a nerd but I installed them with quick disconnects so I can remove the gauge pod with great ease.
Ok guys, good luck with ALL our rides. Even Mayfair.
