Whats a good Descent oil to use ?
Old May 18, 2007 | 03:45 AM
sallyman1's Avatar
sallyman1
Default Whats a good Descent oil to use ?
This topic is probably old but what is a good oil. i bought a used 2004 CTD and dont know what the customer was putting in it? How can i tell if he was using synthetic? or would it matter if i used synthetic or not? If so which rating? 15w40? or just use normal rotella or petro canada 15w40. has anyone heard of using CO-OP dmo 15w40 or Boss Lubricants 15w40? Which is a good oil and fuel filter to use? fram or amsoil? I havent really checked good under hood but where exactly is fuel filter and oil filter located?
Old May 18, 2007 | 04:07 AM
02 cummins 18's Avatar
02 cummins 18
Default RE: Whats a good Descent oil to use ?
I use amsoil it seems to be pretty good,i change every 10 to 12 thous. I also have used synthetic rotella 5-40 was excellent in winter could really see the oil pres increase as it warmed up its about the only oil i have seen the pressure go up after warmup instead of loosing pres as it heated up
Old May 18, 2007 | 05:38 PM
DBLR's Avatar
DBLR
My self I use Amsoil 5w30 HDD oil year round. But not knowing what the other owner used or how many miles are on your engine I would go with one of these oils, Chevron Delo 400, Valvoline Cummins Blue, Mobile Delvac or Exxon HD. My self I tried the Rotella 5w40 oil and was not very happy with it so I can not recomend it.
Old May 18, 2007 | 06:28 PM
Mayfair's Avatar
Mayfair
I'm using regular ole Rotella T with no problems that I know of. Been using it since the truck was born.
Old May 18, 2007 | 07:00 PM
JimmyDiablo's Avatar
JimmyDiablo
ORIGINAL: Mayfair
Do you use any stabilizer like Lucas or oil additive with it? I have have been using synthetic since 16years old, I know about break in with the ctd but for some reason just feel more confortable with synthetic.
Old May 18, 2007 | 07:25 PM
Drew's Avatar
Drew
delo 400 is what I used before I switched over to Amsoil.
if you can get on the prefered customer program you can get some good discounts
Old May 18, 2007 | 07:43 PM
Mayfair's Avatar
Mayfair
ORIGINAL: jimmydaleo
ORIGINAL: Mayfair
Naah .... just regular ole Rotella. No addtives or anything else, just Rotella. I religiously change it every 5000 miles though. I'd do that regardless of which oil I used though.
Old May 18, 2007 | 10:43 PM
DiEseLjunKy's Avatar
DiEseLjunKy
Ditto the preferred customer deals on Amsoil. Makes them competitive with other synthetics and they are supposed to be the best anyways. I've got a case of MTG and ATF. I need some gear lube and eventually some engine oil too after my truck is broken in. Gonna run a bypass filter too.
