muffler and cat delete
Old May 21, 2007 | 02:59 AM
moconst's Avatar
moconst
Default muffler and cat delete
Is it hard to diy or is the stock exhaust clamped together real well. I tried taking apart exhausts in the past and it was always a pain cause the clamps were so tight they crimped the metal.
So on my 06 will the pipes come apart easily if I do the delet or add a diff muffler? Thanks!
Old May 21, 2007 | 03:37 AM
jakebrake's Avatar
jakebrake
Default RE: muffler and cat delete
If they don't come apart, there is always an airchisel or a sawsall. Usually they come apart fairly easy on newer trucks. Key word being "usually"
Old May 21, 2007 | 03:42 AM
moconst's Avatar
moconst
Im thinking about goin with the mrbp cat back, Any one know how they sound?
Old May 21, 2007 | 04:15 AM
Mayfair's Avatar
Mayfair
ORIGINAL: moconst
Vaaa ROOOOM VaaROOOM .... baa baa baaa baa baaa baaa baaa baaa Vaaaa ROOOOM VaaaROOOOM .....
Sorry, I couldn't resist ....
Old May 21, 2007 | 04:48 AM
moconst's Avatar
moconst
hmm, sounds ok i guess but can you do it one more time so I get a better idea? lol
Old May 21, 2007 | 10:51 AM
FroneDaddy's Avatar
FroneDaddy
I had the MBRP 4" turbo back, but I removed the muffler that came with it and now straight pipe. Both ways sound good, just wasn't loud enough for me with the muffler on it. The MBRP I have is the one with the 5" tip
Old May 21, 2007 | 10:54 AM
cumminalong's Avatar
cumminalong
The exhaust is crimped together tight. The only part I was able to reuse on my '06 was the downpipe. Everything else was crimped so tight, I jsut had to cut it. I was trying to remove it all as a complete system, but the routing of the exhaust wouldn't allow that; mainly where the pipe curves out over the rear axle.
Just break out the sawzall and be done with it; it'll save you a lot of time and effort.
Old May 22, 2007 | 12:47 AM
moconst's Avatar
moconst
Ok, thanks for the help. Im thinking to order the MBRP, sounds like its one of the favs.
Old May 22, 2007 | 12:49 AM
moconst's Avatar
moconst
bump
Old May 22, 2007 | 03:04 AM
Mayfair's Avatar
Mayfair
I cannot reccomend the Aero Turbine enough. I know the MBRP is popular, but I LOOOOOVE my Aero !!!
