Hard starting
Old May 23, 2007 | 01:45 AM
Cumminnotstrokin's Avatar
Cumminnotstrokin
Default Hard starting
My 2006 CTD on occasion is really hard to start it will crank for 15 - 20 seconds before it will start but most of the time it will fire right up. Has anyone else had this problem? I have tried to turn the key to the on position thinking that I did not give the lift pump time to pressurize but this did not help.
Old May 23, 2007 | 01:58 AM
jakebrake's Avatar
jakebrake
Default RE: Hard starting
Any codes?
Old May 23, 2007 | 01:59 AM
Cumminnotstrokin
nothing
Old May 23, 2007 | 02:00 AM
jakebrake's Avatar
jakebrake
No smoke when cranking?
Old May 23, 2007 | 02:05 AM
Cumminnotstrokin
I have not noticed but I will check. My wife has been driving it most of the time since I got a company vehicle. she said that it is getting worse so I will take it and see. What would the smoke indicate?
Old May 23, 2007 | 02:19 AM
jakebrake's Avatar
jakebrake
If there is smoke, that means it's getting fuel and the injectors are trying to fire, possibly low fuel pressure and things like that . If no smoke I would think it would be a bad crank sensor or something along those lines.
Old May 23, 2007 | 02:27 AM
Cumminnotstrokin
I guess I will take it to the stealership for warranty work. I am a little worried about that because the last time they had it for the Month of January!
Old May 23, 2007 | 02:35 AM
jakebrake's Avatar
jakebrake
https://dodgeforum.com/recalls-and-t...800306/TSB.htm
Old May 23, 2007 | 02:50 AM
Cumminnotstrokin
So there is a flash for the ECMso she should be in and out of the shop. Thanks
Old May 23, 2007 | 03:25 AM
Mayfair's Avatar
Mayfair
ORIGINAL: Cumminnotstrokin
You don't think she mistakenly put a little gas in there do ya?
Water in fuel ??
Just throwin stuff out there ...
