My newly arrived 2007 Ram 2500
ORIGINAL: Mayfair
What's a "VGT" turbo, and how is it different than the oneI have now??
ORIGINAL: Drew
. .since the turbo is a VGT
Some turbochargers (normally called variable geometry turbochargers) utilise a set of vanes in the exhaust housing to maintain a constant gas velocity across the turbine, the same kind of control as used on power plant turbines. These turbochargers have minimal amount of lag, have a low boost threshold (with full boost as low as 1,500 rpm), and are efficient at higher engine speeds; they are also used in diesel engines. In many setups these turbos don't even need a wastegate. The vanes are controlled by a membrane identical to the one on a wastegate but the level of control required is a bit different.
