HELP...no power up hills P0148 code
Old May 28, 2007 | 10:39 AM
ntc09's Avatar
ntc09
Default HELP...no power up hills P0148 code
06 Mega cab 8000 miles. Just started yesterday. Tried to go up a 20% grade.
Black exhaust smoke...EGT's rise to 1200. No increase in RPM or speed. Diag code p0148. Could it be a clogged fuel filter???
Old May 28, 2007 | 11:29 AM
Charles Darwin's Avatar
Charles Darwin
Default RE: HELP...no power up hills P0148 code
P0148 Fuel Delivery Error
Narrows it down a bit...
Old May 28, 2007 | 09:13 PM
squirtbottle09's Avatar
squirtbottle09
Yes it could be.
Old May 30, 2007 | 07:42 PM
ntc09's Avatar
ntc09
Turns out...after taking it to 2 different dealships....the fuel filter fell apart. 9320 miles on it....covered under warranty. Super glad that's all it was.
Old May 30, 2007 | 07:47 PM
Drew's Avatar
Drew
better hope your CP3 is ok and the filter media has not clogged or worn anything.
Old May 30, 2007 | 08:04 PM
Mayfair's Avatar
Mayfair
Why do you think it shredded like that?
Are you using any additives?
Old May 30, 2007 | 08:15 PM
Drew's Avatar
Drew
ORIGINAL: Mayfair
probably a filter that passed QAQC with a defect that wasnt seen. . .bet it was a guy on the line that got tanked the night before.
Old May 30, 2007 | 09:29 PM
cumminalong's Avatar
cumminalong
ORIGINAL: Drew
Oooooppps, I knew I shouldn't have filtered my beer with that before I put it in the box. [:-]
Old May 31, 2007 | 01:53 PM
ntc09's Avatar
ntc09
The filter media was intact, but one of the rings (I think the top) came off and was clogging/blocking the inlet port.
Old May 31, 2007 | 03:51 PM
Mayfair's Avatar
Mayfair
ORIGINAL: ntc09
Unless your filter is TOTALLY different than my stock filter was, I can't for the life of me see this happening.
If the top o-ring came off, the filter wouldn't seat at all and I would think it would leak.
These are bad pictures for describing what I'm talking about, but in this picture you can see a filter that I ripped the top off of just to retain the o-ring part
And in this picture you can see how it seats in the canister with the o-ring on
See whatI mean ?
If the o-ring was missing, the canister would leak.
